ecm prom compatability
Subscribe
Nov 6, 2013 | 08:49 PM
need help figuring out if the prom is correct for the computer i have a 85 firebird with the 2.8 i have a 1226870 computer but it has a 16032500 prom
Reply 0
Nov 7, 2013 | 08:33 AM
Re: ecm prom compatability
There should be a 3 or 4 letter code on the PROM, what is it?
RBob.
Reply 0
Nov 7, 2013 | 06:03 PM
9845 thanks for your help
Reply 0
Nov 7, 2013 | 08:04 PM
There should be a 3 or 4 letter code on the PROM, what is it? If stock it is on the silver label.
RBob.
Reply 0
Nov 7, 2013 | 08:05 PM
frh thanks
Reply 0
Nov 8, 2013 | 06:59 AM
FRH is correct for an '85 Firebird with the 2.8l engine. It is FED emissions, with the 700R4 transmission (automatic), and manually controlled A/C system.
RBob.
Reply 0
Nov 8, 2013 | 02:21 PM
thanks for your help uh does would it be worth replacing the 6870 with the later model 7302
from rock auto
Reply 0
Nov 8, 2013 | 02:48 PM
The ECM won't come with a PROM and the '6870 PROM won't work in the '7302 ECM. I don't know if the '7302 ECM is any better, although it likely does has better firmware.
RBob.
Reply 0
Nov 8, 2013 | 10:12 PM
thanks for your help you helped alot
Reply 0
Subscribe
