Help me identify these injectors
Old Apr 1, 2015 | 10:49 AM
devilfish's Avatar
It seems the pre-owner changed out some of the injectors.
I think the grey ones are the stock, but im not sure what the black ones are?
Car is a 1991 TPI vette.
Cheers
Old Apr 1, 2015 | 06:47 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Help me identify these injectors
I'll say that the greenish-gray one on the right is a Multec. Looks like every other one I've seen. I have also seen Multecs with a black body, but the form factor was identical to the greenish-gray one.
That is the lengths of the various lower portions and angles.
One thing about the left injector, the lower number on it appears to be a Lucas number. But the injector doesn't have the right shape, at least to me. Maybe RP contracted out some injectors to Lucas?
Anyway, upgrade and be done with it. Multec's have no reason to be used in an engine.
RBob.
Old Apr 2, 2015 | 12:53 AM
devilfish's Avatar
RBob.
Thanks for the info.
What should I replace them with?
Any tips?
I can mod the bin, but on this car I havent yet a adj fpr, so something that will be a drop in replacement would be nice..
Old Apr 2, 2015 | 08:07 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Get some Bosch injectors, even the older fat body ones will work. Which particular one I can't say. Not sure what the junk yard scene is like in Sweden, but there are a lot of cars made & sold in Europe that use Bosch injectors.
From the Stan Weiss list here is some possibilities (there are even more in the list):
0-280-150-432 22.85 #/hr Saab 4-2.0l, 4-2.3l
0-280-150-433 22.85 #/hr Hyundai
0-280-150-440 23.8 #/hr BMW 6-2.8l
0-280-150-447 22.9 #/hr Audi 4-1.8l Turbo, VW 4-1.8l Turbo
Note that the Bosch injectors have the art number molded into the top portion, makes them easy to ID.
RBob.
Old Apr 2, 2015 | 09:45 AM
devilfish's Avatar
Thanks!
I found these ones on a Swedish junkyard site.
0-280-150-432:
http://www.bildelsbasen.se/?link=ite...st_id=24709916
0-280-150-440:
http://www.bildelsbasen.se/?link=ite...st_id=20689129
$14 each
Will those have the correct flow with the stock 1991 TPI fuelpressure?
I think the stock fuel pressure is 40 to 42 psi with vacuum hose connected and 47 to 48 psi with the vacuum hose disconnected.
Also, im at 300hp at the crank give or take, would they flow enough?
THanks
Old Apr 2, 2015 | 01:18 PM
ULTM8Z's Avatar
Originally Posted by devilfish
Thanks!
0-280-150-432:
0-280-150-440:
$14 each
THanks
If they're 24 lb/hr, they should be able to support that.
Old Apr 2, 2015 | 05:35 PM
southbay08's Avatar
devilfish...the black injector is a Rochester...just as bad as the multec! lol
If you're running 300hp ULTM8Z is correct...24's should be fine
Old Apr 3, 2015 | 04:34 AM
devilfish's Avatar
Thanks!
About the Bosch injectors that RBob mention.
Is it possible to get the injector offset table from Bosch on those injectors?
Any tips on where I can find this info?
Or if I get even better injectors from you at Southbay fuel injectors, can you provide me with that info?
Cheers
Old Apr 3, 2015 | 02:28 PM
southbay08's Avatar
Yes we can sir.
92-Formula
Dec 12, 2015 10:34 PM
Linson
Sep 21, 2015 01:08 PM
abrilnelson89
Sep 17, 2015 10:41 AM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
