WinALDL - Help Needed Please
Old Apr 1, 2019 | 10:03 PM
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
What it all means... I really don't know... please
Old Apr 1, 2019 | 11:01 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: WinALDL - Help Needed Please
Does the map, tps and iac lower down with the engine running ?
Old Apr 2, 2019 | 12:00 PM
Engine: 305 / 350
This is what I got w/ the engine running for a few... and it actually ran without the surging part of the idle, it was just a tad rough...
Old Apr 2, 2019 | 12:16 PM
Engine: Lb9
Transmission: M20
The map seems high at first, not sure what the raw data is but converted it’s almost maxed out at 5v. I think this is engine off zero vacuum and you must live at sea leave to 1,000 feet.
you might want to see what it is engine warm. Looks like you were in a warm up during this snap shot.
Old Apr 2, 2019 | 02:07 PM
Engine: 305 / 350
Old Apr 2, 2019 | 02:18 PM
Engine: Lb9
Transmission: M20
I’m not sure on the battery voltage monitor if this is on b2 of the ecm or not.
Do you have another map to try ?
my guess is a charging system problem or a map.
any error codes like 54 ?
Old Apr 2, 2019 | 03:06 PM
Engine: 305 / 350
No Codes stored, No spare MAP's, but I do have a tested good Alternator and new S-belt I could try. I have a video of the live data as it's running, I'll post it or link to it on break.
Old Apr 2, 2019 | 03:32 PM
Engine: 305 / 350
https://www.youtube.com/watch?v=uIiG...ature=youtu.be
Old Apr 2, 2019 | 03:40 PM
Engine: Lb9
Transmission: M20
Sorry I’m on limited access satellite and the video won’t load.
what is the map value at idle 30-60 kpa ?
Old Apr 2, 2019 | 03:47 PM
Engine: 305 / 350
More like 60-80 then settled around the low/mid 50's.
Old Apr 2, 2019 | 03:49 PM
Engine: Lb9
Transmission: M20
Sounds normal than. Not sure what direction to point you in.
Old Apr 12, 2019 | 07:04 PM
Engine: 305 / 350
Just some new log files.
File Type: txt
File Type: txt
File Type: txt
WinALDL - Log 2 - KNOCK.txt (831 Bytes, 54 views)
File Type: txt
File Type: txt
File Type: txt
File Type: txt
bigals87z28
Aug 29, 2003 04:31 PM
raggedout91RS
Dec 28, 2002 08:07 PM
Paul Riccioli Jr
19
Sep 12, 2002 05:51 PM
dtpmike
Apr 29, 2002 11:51 PM
Scott_92RS
Nov 22, 2001 02:04 PM
