Where is the diagnostic port in my 87 Camaro.
Old May 7, 2019 | 04:25 PM
jbander's Avatar
It takes a OBD1 port, I believe but where is it. I've heard from in front of you right knee in the drivers seat, to next to the Fuse box. Should I be taking off the cover over this area to find it. ? What am I missing here. I always hate to start tearing things apart looking for something when I don't know where it is. Thank You
Old May 7, 2019 | 05:27 PM
Drew's Avatar
Re: Where is the diagnostic port in my 87 Camaro.
Can't really miss it. If you've got the hush panel under the dash, it's behind the little 1x3" plastic cover that looks like it'll just snap off (it does).
Old May 7, 2019 | 06:08 PM
jbander's Avatar
Ok thanks, I'll look again.
Old May 7, 2019 | 06:11 PM
jbander's Avatar
Well my aftermarket oil,temp,volt gauge was up against it. I got to it, Grounded The top right two terminals, turned on the ignition and nothing. This is a different Engine then the one that was in it originally, if that means anything. Thanks for the response.
Old May 10, 2019 | 07:57 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Does the ses/mil light come on with the key on ?
Old May 10, 2019 | 10:30 PM
jbander's Avatar
No the only lightthat comes on is the seat belt light , it stays on for 20 seconds then goes off, none of the rest of the safety/diagnostic lights come on at all. I checked the fuse
Old May 10, 2019 | 11:46 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Check the bulb.
Old Jul 5, 2019 | 06:45 PM
mjwadams's Avatar
Car: 92 RS
Engine: L03 with Holley Sniper EFI, headers
Transmission: T-5, hurst billet shifter
Axle/Gears: 3.08 posi
I would recommend getting an OBD1 "Reader". It isn't really a reader, it is just a plug that connects to your diagnostic port and shorts the pins the same way you would with a paper clip. But it is a lot easier to use than the paper clip. You just plug it in, turn on the ignition and get your code.
This is is the one I got. It also comes with a nice manual that has the codes in it
Amazon Amazon
The diagnostic port is under the dash near the fuses:
1986iroc-z
Jul 29, 2009 01:11 PM
Roadkid91
Oct 14, 2007 01:10 AM
82 Iron Duke
Interior Parts Wanted
May 21, 2006 02:36 PM
FJK
Jun 2, 2002 08:07 AM
