no starting
no starting
Hello, will introduce me. A bit more fanatic of the car. I am from Belgium, a small country opposite you. So have a problem, and with an American car, I have to be with you. I have a camaro 1989, 2800cc, injection. He doesn't want to start, no ignition. Have checked the fuses. Where should I look. there is an alarm on, and the LED will not go out. Regards. Potop
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: no starting
The light that won’t go out is that the security light ?
does the engine rotate over (crank) ?
Engine: Lb9
Transmission: M20
Re: no starting
Not following, if the engine runs your ignition is working.
or do you mean power inside the car ?
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Re: no starting
Pictures are worth 1000 words. I am not aware of any RED LED in the car from the factory. I suspect something may have been added.
Please post a picture of the light and maybe post a video to youtube of what you are describing. Will help with the language translation.
Accused Normal
Jun 13, 2004 11:03 AM
PimpRod92RS
Oct 15, 2002 07:55 AM
