ECM HOW DO U KNOW ITS OUT
Old Apr 29, 2021 | 12:28 PM
tu88formula's Avatar
I HAVE A 88 FIREBIRD FORMULA 305 TBI AND I AM HAVING FUEL PUMP ISSUES I HAVE CHECKED THE GREEN WIRE ON FUEL PUMP RELAY NO POWER TO THAT LINE, THE 20 AMP FUSE NEXT TO BATTERY IS GOOD...BUT I STILL HAVE NOT SIGNAL TO FULL PUMP...HOW DO U CHECK THE ECM TO SEE IF ITS DAMAGED....
Old Apr 29, 2021 | 02:44 PM
ULTM8Z's Avatar
Re: ECM HOW DO U KNOW ITS OUT
I think the fuel pump relay is also controlled by an oil pressure switch. May want to check that first.
Old Apr 29, 2021 | 02:53 PM
i will check that...thank you...
Old Apr 30, 2021 | 07:15 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It is common for the transistor that drives the fuel pump relay to go out on the TBI ECMs. it is also easy to replace with the easily available PN2907 transistor.
https://www.thirdgen.org/forums/dfi-...swap-ecms.html
RBob.
Old May 18, 2021 | 11:11 AM
i do have power going into the ecm but nothing coming out to the rest of car......what could this issue be a bad ecm
Old May 18, 2021 | 11:36 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
If you have no power to anything else, this would stop the car from starting
Old May 22, 2021 | 02:58 PM
correct
but i am getting power to everything, else just not getting power to the fuel pump wiring from the fuel box ..all of the fuses are good my ecm is getting power ..but still not getting power to the green/white on the relay...but i can jump the relay with a paper clip and the fuel pump turns on.....what would cause this...
a bad relay
SRF
Apr 16, 2015 11:14 AM
John Galt
Nov 21, 2011 11:45 AM
AkitaMan
May 21, 2009 10:50 PM
xz510
Oct 31, 2005 02:23 PM
88TAproj
Nov 7, 2003 07:04 PM
