How do you disable VATS in AUJP Bin?
Old Jan 9, 2024 | 02:29 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
I'm preparing to switch from MAF to SD using AUJP bin. I cannot seem to find the line item in the AUJP bin to disable VATS. Can someone please point me in the right direction?
Fred
Old Jan 9, 2024 | 02:34 PM
ULTM8Z's Avatar
Re: How do you disable VATS in AUJP Bin?
What tuner software are you using?
Old Jan 9, 2024 | 03:05 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If tuner pro v5 its a flag, tuner cat its under tables, ecm switch.
Old Jan 9, 2024 | 04:54 PM
Fred SS's Avatar
Transmission: 2004r
I am using Tuner Pro V5. I just updated it yesterday. I will look at the Flag. I swear I did not see it there.
Fred
Old Jan 9, 2024 | 05:03 PM
Fred SS's Avatar
Transmission: 2004r
The first eight line items under Flags start with the text "Switch 16". Then in parenthesis there is a string of text that includes the following (VATS TCC -R-NO VATS OLP) - Bit" Followed by a Bit number, then more text with three of four number and letters.
Fred
Old Jan 9, 2024 | 07:39 PM
Engine: Lb9
Transmission: M20
Here's aujp with vats delete and the xdf i used with $8D
File Type: bin
File Type: zip
Old Jan 9, 2024 | 09:17 PM
Fred SS's Avatar
Transmission: 2004r
Thank You Tuned Performance. I will check it out.
Fred
Old Jan 9, 2024 | 09:29 PM
Fred SS's Avatar
Transmission: 2004r
When I started this effort, I downloaded files from the TunerPro website. I downloaded "Super_8dm2". That file is different than the file Tuned_Performance posted here. I got allot of learning to do. Thank You Tuned_Performance.
Fred
Old Jan 9, 2024 | 09:42 PM
Engine: Lb9
Transmission: M20
Are you using super aujp or just aujp ?
Old Jan 10, 2024 | 01:27 PM
Fred SS's Avatar
Transmission: 2004r
I am using AUJP. I have read the "Read Me" file that comes with Super_AUJP but I am not at that level yet. So I will stick with just AUJP for now.
Fred
Old Jan 11, 2024 | 04:24 AM
ULTM8Z's Avatar
For the 8D xdf, In the description for these series of switches it says...
b6, 1 = USE A/D BATT FOR INJ Lk Up, (else use PUMP VDC) OLP= Open Loop Purge VATS= VATS Enable b3, 1 = LET LOW TPS DISABLE CCP 4thNO= 4th Gear N.O. b1, 1 = 16 Hz CCP SOLENIOD IN USE TCCR=TCC Control On=RPM
So it would seem that the correct one is
Switch 16 (VATS TCC-R 4th-NO VATS OLP) - Bit 3 - B3
Old Jan 11, 2024 | 10:28 PM
Fred SS's Avatar
Transmission: 2004r
Thanks ULTM8Z. I was wondering about those line items in the Super_8dm2.ecu file that I downloaded from the TurnerPro website. As Tuned Performance said, the VATS disable in 8D is simply a flag that you uncheck. Similar to MAF.
Fred
91350rs
Jun 23, 2009 08:38 AM
porkyzilla
Jun 6, 2007 01:06 AM
Doward
Nov 12, 2005 08:31 PM
kevosiroc
Nov 18, 2002 09:20 AM
slowTA
Jul 3, 2001 09:14 PM
