747 users...try this ECU...
Old Aug 14, 2002 | 03:55 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
My edited WinBin ECU file for the 747 is on the DIY ftp site. It's called 747-mine.ecu. Give it a try and let me know of any errors please.
ftp://ftp.diy-efi.org/incoming/
Old Aug 14, 2002 | 11:31 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Wow, great job on this .ecu
Can't find anything wrong yet!
Old Aug 15, 2002 | 01:23 AM
Silverado5.7L's Avatar
Yours is the first ecu other then the one that came with winbin.14 that has worked.
I'm new, but I like what you added.
Old Aug 15, 2002 | 12:40 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
V8 astro,
I might just be blind but I didn't see a max IAC limit in your .ecu. It might just be under a different name that I missed.
Old Aug 15, 2002 | 03:23 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
It's called Max retract IAC steps...in the values tab.
I'm glad it worked out for you.
Old Aug 22, 2002 | 11:35 AM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
I noticed that in your .ecu under array, for TCC limits you have listed them in MPH, in tuner CAt theses values are % TPS.
No I just read it wrong again, your right!
Old Aug 24, 2002 | 12:43 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
In your next release, It might not be a bad Idea to add the TCC forced lock-up in MPH @ 0x56E. Maybe even some other TCC params.
I say this because a few of us are finishing the 1/4 at over 100mph, which just happens to be the stock value, not really a good idea to have it locking at high rpms with a big stall.
Old Aug 24, 2002 | 01:02 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
0x56E you say...lemme get on that.
Old Aug 24, 2002 | 01:15 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Here it is. I think that's all of the TCC stuff.
ftp://ftp.diy-efi.org/incoming/7747.ecu
or
ftp://ftp.diy-efi.org/incoming/ and just look for 7747.ecu
Old Oct 2, 2002 | 05:34 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Astro,
I have been having problems with max/min async PW values. It seems when I change the max value it effects the min value. Not sure maybe its just my computer, not sure. Let me know if they work fine for you.
Edit: It appears that when changing the min async bpw, to say a value of 002D, when you save the file , and re-open it the value magiclly becomes 2D2D.
Old Oct 2, 2002 | 06:29 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
I see you figured that one out too. I have the same problem. I have no been able to get WinBin to do double byte values. I may try another sceme. Such as doing the double byte values as an array with two columns.
I'll post back when I make the change.
Ok I tried putting the double byte values as an array. Looks like you can edit the bytes one at a time, but anything that is a DB the conversion doesn't work. This is because the first and second byte are treated as two different numbers so the WinBin converts them independantly.
If there is a DB value of $0318, it is not converted to #792. It looks at it as $03 and $18. So you get #3 and #24($18) converted separatly.
If you still want the new ECU lemme know...
Old Oct 2, 2002 | 06:52 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
If you could email my the ecu @ ryanhart@shaw.ca that would be great.
Another topic: My TCC doesn't lock up. All my boundrys seem in check, I do get a "NO high gear" flag in winaldl. Just wondering if any of the "flags" in winbin have any thing to do with the TCC. There is one or two that have TCC in there name but I don't know what there for. Just wondering if you have any knowlodge on this.
Old Oct 13, 2002 | 12:00 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
In your ecu the value "min temp for closed loop" yeilds a different value than that of tunercat. Changing one does move the value in the other program, so It s the same constant, just difffernt values.
Old Oct 14, 2002 | 01:11 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
I've found that some of TunerCats conversions are not the same. I will not say they are wrong...but I get my conversions right from the ASDZ 747 hack.
Code:
LD299   FCB  64     ; 35c COOL, Min for CLS LP Enable
So if you divide 35 (*c coolant) by 64....you get .546875. This is what is used for my conversion. I've used the same method for the other 100 entries I added to the ecu file so far.
What does TunerCat use?
Old Oct 14, 2002 | 06:02 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Code:
V8Astro, this should be the correct conversion:
C = (N * 0.625) - 5
C is temperature
N is the bin value
This holds true for the coolant value in L0021. The '747 also uses ADC counts, can drive 'ya crazy.
RBob.
jonarotz
Dec 7, 2004 09:20 AM
SABLT194
Jul 12, 2004 09:35 PM
Grumpy
Nov 7, 2003 11:01 PM
Scott T
Sep 13, 2003 01:29 PM
Brent
Apr 26, 2001 04:02 PM
