DIY WBo2
Old May 8, 2003 | 01:49 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
DIY WBo2
anyone know the compenents ill need to make a wide band o2 sensor? and how to put it together?
Old May 8, 2003 | 02:03 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: DIY WBo2
Go here:
www.diy-wb.org
They sell bare PCBs along with parts kits. For the sensor there is another thread (active today) for purchase:
https://www.thirdgen.org/techbb2/sho...hreadid=176840
RBob.
Old May 13, 2003 | 02:56 PM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
Is there anyone selling assembled boards? I have virtually no experience soldering, so if I could purchase an assembled board than I would definately be a buyer.
Anyone interested in making a couple of dollars to assemble it?
By the way I might be able to have a source for the NTK Sensors for under $150.00 USD...I'll know by Monday
Old May 13, 2003 | 03:03 PM
black87c4's Avatar
Car: has 4 wheels
Engine: hampster
Transmission: rubber band
The board is pretty easy, everything is layed out nicely and you can always practice on something else first so give it a shot and just take your time and i think you'll find you can do it.
Old May 13, 2003 | 03:12 PM
Engine: 3.0
so a novice should be able to build this? I have a soldering gun, and I am a very capable person, just don't want to build it and it doesn't work!!!
Also what interest would there be in a NTK sensors for $150.00 USD? I might have a small supply available to me(working on it as we speak). I would need to get solid confirmations, after I confirm the availability...but how many of you guys would be interested?
Old May 13, 2003 | 03:22 PM
black87c4's Avatar
Car: has 4 wheels
Engine: hampster
Yes I think so, like i said take your time. Solder the resistors on first, then the caps, then the transisters. Maybe even group all the parts and stick them in a styrofoam piece, you know all the 1k res. together, etc. Make sure you check the resistance on the resistors unless you like guess the color bands.
Old May 13, 2003 | 04:44 PM
Engine: 3.0
OK, I will check my source for the O2 Sensor...if that works out I'll order a parts kit and pcb and start assembling.
I read another post that it's possible to capture the WB readings via the ecm and display the readout in a ALDL software like Craig Moated ECM852!!!! That'll be real trick!!
Old May 13, 2003 | 10:30 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
poncho:
I am currently looking to purchase a wideband o2 so i cna build the kit as well(or talk my electronic freak buddy into it).
If u can get them at 150 i would almost positively buy one
please let me know
greatly appreciated
Jeremy
Old May 13, 2003 | 11:41 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
It's really against the agreement to pay for having the board soldered up. However bartering is fair game.
I'm no EE, not even close, and my first board worked. Even bartered a few away.
It's meant to be educational. Soldering is a good skill to have uf you're going to be working on EFI stuff anyway.
BTW, read the site, and a soldering iron will work better then a gun. RS has soldering irons that will get you by.
Old May 13, 2003 | 11:56 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
alright cool. so they sell kits with all the parts and its up to whoever buys it to assemble? thats not bad at all, we did taht in electronics tech with kits we bought. i know i could assemble it. so what is the total cost for the WBO2 and the interface? also after i have it in could i just hook a volt meter up to it and have a friend hold it and see where my WOT A/F ratio is?
ULTM8Z
Sep 16, 2015 09:15 AM
Catcher55
Aug 15, 2015 07:08 PM
Greenshamrock77
Nov 19, 2001 12:12 PM
89ProchargedROC
Oct 19, 2001 09:40 PM
Tim Burgess
Oct 18, 2001 02:51 PM
