Cylinder Volume
Old Jun 11, 2003 | 10:08 PM
tpi_roc's Avatar
Cylinder Volume
Anybody know what address cylinder volume is at?
Old Jun 11, 2003 | 10:28 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
<marquee><h3>In?</marquee></h3>
Old Jun 11, 2003 | 10:30 PM
tpi_roc's Avatar
730
Old Jun 11, 2003 | 11:40 PM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
L86DD in ANHT hac, 2 bytes
Old Jun 13, 2003 | 02:07 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Can someone with hexadecimal knowledge please explain to me why this doesnt seem right? Or explain what im not seeing.
Old Jun 13, 2003 | 02:47 PM
tpi_roc's Avatar
What is it that doesn't seem right?
by the way thanks hectorsn
Old Jun 13, 2003 | 03:05 PM
shaggy56's Avatar
Car: 71 Nova
have you ever looked at the aujp.bin? there is no value at 6dd.
Old Jun 13, 2003 | 03:17 PM
tpi_roc's Avatar
I'm running the AUJP bin
and there deffinatly is a value
Old Jun 13, 2003 | 03:20 PM
shaggy56's Avatar
Car: 71 Nova
Can you send me a untouched version of that bin. as the one i have has 00 in that location using a hex editor. maybe mine is off by someting because 6de seems to have the correct value.
Old Jun 13, 2003 | 03:22 PM
tpi_roc's Avatar
Use a bin editor, not a hex editor
you can get unmolested bins for the 730 at:
ftp://ftp.diy-efi.org/pub/gmecm/bins/1227730/
Old Jun 13, 2003 | 03:45 PM
shaggy56's Avatar
Car: 71 Nova
no luck still get the same result. I must not have the right editor. I downloaded what seemed to be a bin editor and doesnt seem any different than a hex editor.
Old Jun 13, 2003 | 03:52 PM
tpi_roc's Avatar
get winbin or gmecm
then get an ecu, there's another thread with ecu files I just posted that will work
then a fresh unmolested bin
Old Jun 13, 2003 | 04:01 PM
shaggy56's Avatar
Car: 71 Nova
So why would an unmolested bin compared to one i edit in gmecmedit be so different? For instane populate the hex code for an untouched bin and before it says 6dd is 00 and 6de is 9F(159). Then edit it with gmecm edit and it changes both 6dd and 6de to a new value. Why is it originally just 6de thats different and then they both change after the edit. Wouldnt we just want the one value changed rather than two different changes?
Old Jun 13, 2003 | 04:05 PM
tpi_roc's Avatar
The cylinder volume in the AUJP is located at 6DD for 2 bytes, you got 00 and 9F. Know what 9F is in decimal?
Its 159, the cylinder volume of a 350cid V8
I dont see any problems?
Old Jun 13, 2003 | 04:16 PM
shaggy56's Avatar
Car: 71 Nova
Exactly now change it in gmecm edit to another value and see what its says. For instance change it for 383 which is calculated 175 (Af). The editor will change the two bytes to Af Af which is 44975. Im not doubting the location but seems the ecu must be incorrect. If you change it back you will still get 9f 9f which is 40863. Just be nice to get this working correctly. The only way I could get it to work is to edit the hex myself.
Old Jun 13, 2003 | 06:15 PM
hectorsn's Avatar
Car: 78 Regal
Transmission: M20
Axle/Gears: 4.10
Shaggy, just change 6DE then manually like you did. Or correct the ecu. Unfortuantely you have already answered your own question.
Linson
Oct 24, 2025 02:00 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
