Still Getting Knock
Old Feb 2, 2004 | 04:14 PM
IroczInOz's Avatar
Still Getting Knock
I have taken away 3deg of spark adavnce in trouble areas mostly in the higher regions (70+kpa - 100kpa 2000-4400 rpm) I have also added fuel in the power enrich spark advance tables. My values are now set at
4800 - 8.79 originally on stock chip value =5.98
3200 - 8.79 originally on stock chip value =5.98
2000 - 6.33 originally on stock chip value = 3.87
1200 - 1.41 originally on stock chip value = 0
400 - 0
But I am still getting knock. BLM are in between 125-131 so they are pretty spot on.
Should I still add more fuel or would it be too much? Or should I just keep taking away spark?
Car running at 182deg F consistently. 86 Camaro 305TPI MAP (using a 1992 305 Z28 chip)
Old Feb 2, 2004 | 05:35 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Still Getting Knock
You got a 1227730 ecm's chip to run in a 1227165 ecm?.
Or you got something wrong in what your wrote?.
Old Feb 2, 2004 | 06:08 PM
IroczInOz's Avatar
Nah should have made it clear I have a 7730 ECM also. Now that I think of it I have not logged all the BLM levels. I have not set the PE TP% higher than 80% so maybe up high it is running a little lean. I will add some more VE value up high and see if that helps at all in my next test run. Looking at the data now I saw a few times of 10deg retard in spark when I was in 95+kpa and above 3000rpm. But it is getting better maybe it still needs less advance but will try adding some VE and see how I go.
Mike
Old Feb 11, 2004 | 01:41 AM
IroczInOz's Avatar
Well I have taken out an extra 2 deg of timing in the problem areas increased fuel by another 1.5%.
Took the car out again and still getting timing retard even up to 11deg!
Looks like I have to take out even more. Will not be much left if I keep going as I am going.
Old Feb 11, 2004 | 03:46 AM
JohnL's Avatar
Is your knock sensor the correct one for the knock board on the memcal?
John
Old Feb 11, 2004 | 09:04 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Cut and paste your main spark and VE table, maybe their's something obviously outta speck.
Old Feb 11, 2004 | 03:15 PM
IroczInOz's Avatar
Okay below I have pasted the tables and also the power enrich vs spark.
Old Feb 16, 2004 | 02:40 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Correct me if I'm wrong, but didn't you say you are adding FUEL to the SPARK advance Power enrichment?? Isn't that table for adding SPARK and thus increase your knock?
Old Feb 16, 2004 | 09:24 PM
IroczInOz's Avatar
I don't think so?? I think that table is for adding a percentage of fuel at certain RPM.
Damn maybe you are right having a look at the table again. What is the table called for adding fuel at a certain RPM range as I thought that was the pwr enrich vs spark advance.
Old Feb 17, 2004 | 02:38 AM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Zero out the PE Spark Advance table and if you want to add more timing, do it through the Extended SA table.
If you want to add fuel, you need to do it through the VE2 table to my understanding. I'm still a novice to, but you're headed off in the wrong direction.
If you haven't tried TRAXION's Super AUJP chip yet, you might want to check it out to see what works and compare settings.
I've got a '91 GTA L98 that I'm having similar problems with here: https://www.thirdgen.org/techbb2/sho...hreadid=223867
I've also pulled out enough spark to be back at stock levels, so I'm going to try adding some fuel now. Hopefully I'll be able to data log tomorrow and will have some info tomorrow.
Old Feb 17, 2004 | 10:39 AM
http://www.sunflower.com/~leroy/P4/
Look at section 9 and 11. This is for the Typhoon/Syclones' 749, but the PE strategy should hold somewhat true. There is spark advance added to the main spark advance in PE. There is an air/fuel ratio commanded for the PE fuel.
It's good reading if you haven't seen this document yet.
Later,
Jeremy
Old Feb 17, 2004 | 06:07 PM
IroczInOz's Avatar
Thanks guys looks Iike I really goofed up here I have zeroed out that table and see how the car runs now
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
