Problem with TunerPro 3.06 and ECU 8d_v03
Old Feb 24, 2004 | 10:54 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
I applied the patch to get the VE tables extended to 6400RPM and am using the correct ecu file to recognize the new table. However in TunerPro the new table will not save any changes???
Old Feb 24, 2004 | 10:55 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
send me the bin and ecu.
mmansur at hotmail
Old Feb 24, 2004 | 11:00 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
you have mail
Old Feb 24, 2004 | 11:02 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
Patch to V3.06?
Old Feb 24, 2004 | 11:29 PM
Mangus's Avatar
Transmission: T5WC
the stuff you sent works fine. can you try again and verify that theres actually a problem, and if so, be absolutely specific as to what it is and how to make it happen?
Old Feb 24, 2004 | 11:36 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
Edit this table.....Volumetric Efficency vs. RPM vs. MAP (Extended) I save it and close reopen and the values are not changed????
Old Feb 24, 2004 | 11:37 PM
Mangus's Avatar
Transmission: T5WC
they sure are. no idea whats up on your end. are you sure you actually changed the value in the table to begin with?
Old Feb 24, 2004 | 11:44 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
ok whats happening is that it will not save anything pasted into it from excell. I am trying to transfer my VE data from another table into this bin...
Old Feb 24, 2004 | 11:45 PM
Mangus's Avatar
Transmission: T5WC
aaah. i'll look into that. new feature. there has to be bugs or the feature would suck. :-D
Old Feb 24, 2004 | 11:48 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
Old Feb 24, 2004 | 11:49 PM
Mangus's Avatar
Transmission: T5WC
nope. that works too. here's what i did (successfully):
1) open the extended table.
2) right click -> copy table to clipboard
3) go to excell, paste table
4) make changes in excel
5) select the entire table in excel, then copy to clipboard from excel
6) back to tunerpro, right click on the table -> paste from clipboard
7) click save (table closes)
8) open the table again. changes are still there.
9) for gits and shiggles, save the bin to file, close tunerpro, reopen tunerpro, open the table. changes still there.
Old Feb 24, 2004 | 11:54 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
Ok gonna give that a try
Old Feb 24, 2004 | 11:57 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
I must be retarded cus I cant get it to work
Old Feb 25, 2004 | 12:01 AM
Mangus's Avatar
Transmission: T5WC
one of us might be.
1) what happens when you edit a different table using the same method?
2) what happens when you edit a table in tunerpro without the copy/paste stuff?
3) what happens if you open the 6Ev011 ecu file and apyp/arap bin and edit a table?
4) what about constants/flags?
anyone else see this issue?
m
Old Feb 25, 2004 | 12:09 AM
Car: 1989 Iroc-Z
Engine: 350ci SBC
1) Using the same method it will not save.
2) Without the copy and paste it will save fine
3)Using the copy paste stuff in the 6Ev011 ecu file and arap bin it will NOT save.
4) flags save fine.
I am using XP and Office XP?????
Old Feb 25, 2004 | 12:11 AM
Mangus's Avatar
Transmission: T5WC
are you copying the entire table in excel (click on the upper left cell, shift-click on the lower right cell, then select copy)?
when you paste into tunerpro, can you confirm that the changes are there before you click save? maybe make drastic, ridiculous changes just so they're obvious?
Its working fine and dandy for me.
Old Feb 25, 2004 | 12:47 AM
Car: 1989 Iroc-Z
Engine: 350ci SBC
Sorry to waste you time....I must have messed up the conversion factor on one of the tables by mistake...
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
