165-7749 Complete
Old Apr 19, 2004 | 09:42 AM
ED89's Avatar
Car: 89 vet
Engine: v8
Transmission: Automatic
165-7749 Complete
Finally Finished converting my vet over to the 7749. All I can say, I shoud have done it sooner. The car idles like a champ and response is greatly improved. I would like to just thank everyone on the forum who did it and published the great information.
ED89
Old Apr 23, 2004 | 08:40 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'd love to see your final runnin bin sometime, to get an idea of how your fueling is on the 383.
-- Joe
Old Apr 26, 2004 | 08:35 AM
ED89's Avatar
Car: 89 vet
Engine: v8
Would love to after I finish dialing it in. This week I will be working on getting a set of 42# injectors. For the time being I made my 24#ers look like 30's, so I haven't made any wot runs yet. All I have worked out is Idle, light-medium throttle and cruze. I will keep you posted.
ED89
Old Apr 26, 2004 | 01:21 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: 165-7749 Complete
Assuming your running the 58 code
Once you get close, you'll see that there is a delta TPS AE by rpm, that can really perk a car up, alot. Not all respond the same but in the couple I've played with there is something to be gained there.
If you have your MAT in the plenum, great, if not, it would serve you to put it there. The Syclones had it there, and the MAT fuel correction is designed for it being there.
Old Apr 26, 2004 | 01:45 PM
ostrich's Avatar
Car: 85 Iroc-Z
Engine: 383, Vortech SQ
Axle/Gears: Stock 7.5 w/ shafts, 3:73
ED 89, I PM'd you for some information. I'm also working on a 383 for a Camaro with a Vortech SQ. Grumpy from your post the MAT sensor is better in the manifold or the air pipe going in. I know on a normal aspirated car people put it in the air tube for sometimes a little more gain? I'm building a new intake pipe and was going to weld a bung it it for the MAT, but may not now.
Old Apr 26, 2004 | 02:12 PM
ED89's Avatar
Car: 89 vet
Engine: v8
Re: Re: 165-7749 Complete
Yes, I am running $58
Thanks for the tip, I Will Keep the AE delta tps in mind .
As for the mat sensor never moved it. Need it for waste gate controlled WI
The only thing that caught me by surprise is the default rpm when in aldl mode the bin I started with was set for 1250rpm.
Is that normal for most bins?
Ed89
Old Apr 27, 2004 | 12:23 AM
L8ON's Avatar
Any pics of the motor and blower setup?
Old Apr 27, 2004 | 12:52 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
The 58 code assumes the MAT sensor is actually in the manifold.
The sensors locations are done for a reason. Typically moving a sensor to lie to the ecm is for folks that really don't understand what they're doing. If one wants to properly enrichen the engine you change the fuel tables as necessary.
Old Apr 27, 2004 | 12:53 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Re: Re: 165-7749 Complete
+-, yes.
6speedIROC
16
Mar 15, 2023 08:33 PM
sailtexas186548
Feb 17, 2017 03:07 PM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
topteam54
Oct 6, 2015 12:21 AM
MORREALE5
Sep 13, 2015 09:01 PM
