Has anyone used this USB adapter???
Old Nov 28, 2004 | 01:32 PM
jonarotz's Avatar
Car: 91 Z28
has anyone used this adapter or one like it before with any success? I am asking because I just got a new laptop and it only has USB ports. I need the 9 pin adapter for my ALDL cable and I need the 25 pin adapter for my chip programer. This one seemed like a good one to use because it has both. Whats your guys' opinion?
http://cgi.ebay.com/ws/eBayISAPI.dll...725235604&rd=1
Old Nov 28, 2004 | 02:12 PM
SBNova's Avatar
The only one I got to work for me was from Radio shack. It might be worth a try though, as mine was twice as much $.
Old Nov 28, 2004 | 02:52 PM
jonarotz's Avatar
Car: 91 Z28
Is this the one your talking about
http://www.radioshack.com/product.as...ct%5Fid=26-183
Do you use it for your programmer as well?
Old Nov 28, 2004 | 05:01 PM
JPrevost's Avatar
Car: 91 Red Sled
I've tried 3 belkin adaptors with my serial hardware and none of them have worked (even when the port is recognized by windows). The RadioShack adaptor is the only thing that's worked for me with all my datalog/programming hardware.
I just think it's funny that they sell the adaptor with the drivers on the floppy disk. 98% of laptops missing serial ports are also lacking in the floppy drive department!
Old Nov 28, 2004 | 06:57 PM
jonarotz's Avatar
Car: 91 Z28
JPrevost
Do you have the one I gave a link to above?
Old Nov 28, 2004 | 07:04 PM
JPrevost's Avatar
Car: 91 Red Sled
Originally posted by jonarotz
JPrevost
Which above? There's 2 links, the first link, no, 2nd, yes.
It's worth a shot if it's half the price.
Old Nov 28, 2004 | 07:33 PM
jonarotz's Avatar
Car: 91 Z28
I meant the radioshack one. Thanks for your help. I think that I am just going to get the radioshack one and be done with it. If I buy the one for half the price I might end up still paying for the radioshack one in the end. I might as well just do it and get it over with.
Old Nov 28, 2004 | 08:40 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
I'm not aware of any way to convert USB to parallel (for your programmer).
Old Nov 28, 2004 | 09:04 PM
jonarotz's Avatar
Car: 91 Z28
JPrevost
You said you are using the radioshack adapter/converter for your programmer as well right?
What programmer are you using?
Old Nov 28, 2004 | 09:06 PM
SBNova's Avatar
The shack link looks like mine. I bought mine in person at the store because they said if it didnt work I could return it within 30 days or something. I figured I couldnt lose- and it turned out it works fine- except for teying to connect to Tunerpro Rt's ALDL function and to datamaster. It wont work. It works great on WinALDL though. I agree with mangus- I dont know what your gonna do about the 25 pin for your burner. You really dont have a parallel port?
Old Nov 28, 2004 | 09:50 PM
92GTA's Avatar
Only a PCMCIA with a DB25 dongle will work for that and they are like $200...
Old Nov 29, 2004 | 01:19 AM
Mangus's Avatar
Transmission: T5WC
TunerPro RT will soon happily support USB->Serial converters when using 160 baud (it doesn't currently, however it should work with 8192 baud just fine currently).
Old Nov 29, 2004 | 06:38 AM
JPrevost's Avatar
Car: 91 Red Sled
To clarify, I use the romulator which is serial. My laptop still has a parallel port.
edit- I also have a pegasus port replicator that is USB 2.0 which has a parallel port and serial, both work.
Old Nov 29, 2004 | 08:48 AM
jonarotz's Avatar
Car: 91 Z28
Thanks for clearifing. It looks like I might be screwed. I think I am either going to buy the burn 1 from Craig or just burn chips at home on my desktop. Thanks guys for all your input.
Old Dec 1, 2004 | 06:52 AM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Most of the USB-serial converters have trouble with the 8192 baud rate for ALDL datalogging. However, they mostly all work with the 2400/4800 required for WinALDL 160 baud. Also, they should mostly all work for 115.2k baud such as needed for serial emulators.
Like was mentioned, there's no good USB-> parallel converter out there. It's just not feasible for what is typically done with the parallel port. There's stuff out there, but as soon as you read the fine print, you see "Only works with printers" and that's pretty much the case.
Old Dec 1, 2004 | 11:47 AM
JPrevost's Avatar
Car: 91 Red Sled
My pegasus ($100) port replicator's parallel port works with my pocket programmer, just tried it out. Did a read and then a write to an AT29C256.
Old Dec 24, 2004 | 04:29 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Guys,
Hope I'm not resurrecting a worn thread. I have been trying to get my ZT-2 scanning done on my WinXP SP2 machine. I have been trying the RS USB-Serial adapter cable. This is the cable some of you like SBNova have been using for the ZT app. I have been able to load the driver for the cable and I can see it in the Device Manager drop down along with the port assigneed. Now for what I don't understand. If I boot up the laptop with the cable plugged in, it'll show up. If the laptop is booted up, then I plug the cable in, Windows wants to install driver although its already been installed. When I do this, the port previously assigned is "in use" and it will assign a new port. Unless I uninstall the driver, the ports remain assigned even though the cable is disconnected from the laptop. Anyway, thanks for your help and Merry Christmas/Happy Holidays.
InfernalVortex
Apr 20, 2021 11:31 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
romcjr
Sep 17, 2015 05:18 PM
