Stock 89 305 tpi Auto Bin File?
Old Apr 18, 2005 | 10:55 PM
borgx's Avatar
Car: 1987 Pontiac Trans Am GTA
Transmission: WorldClass T5
Axle/Gears: 3.70
Does anyone have a stock bin file for an 89 305 TPI Auto car that you could email to me? I do not know the part number or anything so finding one is almost impossible for me... sorry...
I have removed the cold start injector and done several other mods to my 87 with a 305 auto and I need this file to start the tuning process.
Thanks!!!!
Old Apr 18, 2005 | 11:26 PM
siggy_freud's Avatar
Car: 1966 GMC
Transmission: Th-350
You should be able to find one on www.moates.net/files
I believe you are looking for a 6E computer definintion file and an ARAP.bin file.
Old Apr 19, 2005 | 08:36 AM
borgx's Avatar
Axle/Gears: 3.70
I am definitely looking for a 6E ECM file... I have the definition file, just need the bin. I have the ARAP bin file, but I thought that was for a 350 only. I'm looking for the bin for the 305. Are they the same??
Old Apr 19, 2005 | 10:06 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
From the TGO Tech Center FAQ:
Camaro:
89 5.0-F A/Trans(MD8) Fed, 2.77(GH3) 2.73(GU2) 16129297 9298ANYH
89 5.0-F A/Trans(MD8) Calif, 2.77(GH3) 2.73(GU2) 16129383 9384ANYZ
89 5.0-F M/Trans(M39) Fed, 3.08(GU4) 16129337 9338ANYR
89 5.0-F M/Trans(MK6) Fed, 3.45(GM3) 16129349 9350ANYS
89 5.0-F M/Trans(MK6) Calif, 3.45(GM3) 16129359 9360ANYT
89 5.0-F M/Trans(M39) Calif, 3.08(GU4) 16129365 9366ANYU
Firebird:
89 5.0-F A/Trans (MD8), Fed, 2.77(GH3) 2.73(GU2) 16133473 9334ANYC, 3506APYR
89 5.0-F A/Trans (MD8), Calif, 2.77(GH3) 2.73(GU2) 16133475 3513APYT
89 5.0-F M/Trans (M39), Fed, 3.08(Gu4) 16133478 3526APYX
89 5.0-F M/Trans (MK6), Fed, 3.45(GM3) 16133630 9375ANYX
89 5.0-F M/Trans (MK6), Calif, 3.45(GM3) 16133632 9379ANYY
89 5.0-F M/Trans (M39), Calif, 3.08(GU4) 16133988 9389ANZA
There is also Mike's site:
http://www.eecis.udel.edu/~davis/z28/
Rbob.
Old Apr 19, 2005 | 11:45 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
The ANZA bin that is out there was read directly from my '89 305 manual Trans Am (CA emissions). It is the last code revision GM released for the configuration.
Let me know if you can't find it and I'll send it to you.
Old Apr 19, 2005 | 06:04 PM
borgx's Avatar
Axle/Gears: 3.70
As far as I can tell, I need the file ANYC and/or APYR ... I've got a 305 Auto...
Do you have that file?
BTW... Craig Moates' file library has been hacked and there are no files t here right now.
Thanks for the help so far!!
Old Apr 19, 2005 | 07:17 PM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
I bought a 89 305 bin a couple of years ago as there are none out there then that I knew of. I can't remember what I did with it though. If you are still looking for one, i can try to find it for you and email it to you.
Old Apr 19, 2005 | 07:49 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally posted by borgx
As far as I can tell, I need the file for ANYH... I've got a 305 Auto...
Well, I just checked and moates site is intact. If he doesn't have the file you are looking for then I again suggest going to Mike's site. I know for a fact that there are stock '89 305 auto bins there. Since you are going to be doing some tuning on your own you can start with anything that is close.
RBob.
Old Apr 19, 2005 | 08:47 PM
borgx's Avatar
Axle/Gears: 3.70
When I used an older link I had it worked. Using the link above in this post and then going to the stock binaries directory you will see a hacker message....
I still did not see the correct binary on the site. I have also looked at Mike's site and did not find it, but I will dig some more. Thanks!
Old Apr 19, 2005 | 09:46 PM
88tatpi's Avatar
Car: Z28HO/TA/Alfa Romeo
Engine: 305-350-502
Transmission: 700R4-5speed
Re: Stock 89 305 tpi Auto Bin File?
Thanks!!!!
I can send you a copy of mine: Stock 89 Trans Am 305/700R4 California version. Just let me know an email address.
Old Apr 20, 2005 | 11:59 AM
borgx's Avatar
Axle/Gears: 3.70
Re: Re: Stock 89 305 tpi Auto Bin File?
borgx@borgx.net
Thanks!!!!!!
jaridjohn
Jul 8, 2024 03:49 PM
1nastygta
Oct 28, 2015 08:51 PM
st.evel07
Aug 13, 2015 06:15 PM
marcusaw
Aug 10, 2015 08:13 AM
Leggman1
Aug 6, 2015 04:15 AM
