wide band o2 sensor replacement
Old 09-13-2005, 11:03 AM
RBMZ28's Avatar
Car: 87 IROC (low 12's)
Engine: 400 sbc .040 over
Transmission: 700r mod
Where can I get a replacement wide band o2 sensor for the innovate wide unit???? I am getting a error 02 heater open message..... someone had mentioned a cheaper place to buy than innovate?????
Old 09-13-2005, 02:37 PM
Ronny's Avatar
FYI:
I FOUND OUT THAT OIL FUMES OR PAINT FUMES WILL KILL THE WB 02 SENSOR. I BELIEVE IT IS VENTED TO OUTSIDE AIR.
i had both. car in paint shop and oil filter bracket(??) was leaking oil past seal onto ext. pipes. DOA. i think it was $80. Innovate.
Old 09-13-2005, 02:49 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Cheapest way? Hook up at an Audi or VW dealer.
Second cheappest way? Googe it, the part number comes up at several vendors for tons less than Innovate charges
later
Jeremy
Old 09-13-2005, 05:48 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: wide band o2 sensor replacement
*CLOSELY* inspect the harness to sensor connector. Any corrosion will generate that error message. Be sure that connector is not exposed to the elements, without weatherproofing the wires where they go into the harness side connector.
Old 09-13-2005, 11:40 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
"Error 02" could also be the sensor is to hot. Innovate sells a heat shield or you could try place the sensor further back on the exhaust.
ps VW retailer over here charge 500$ for a sensor
/N.
Old 09-14-2005, 08:26 AM
brutalform's Avatar
Try this http://www.innovatemotorsports.com/index.html
I dont know if you are aware of their site, but,
there is a wealth of information on their site. If you dont have their manuals, you can download them I think, and it tells alot about fabbing up yourself a heatshield etc.
As Jeremy said. A VW sensor is the one.
Old 09-14-2005, 01:09 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
www.1stvwparts.com
Put in part number 021906262B
It is $38.29 + shipping. Mine totalled $46.24 shipped to my door. I ordered it a month ago and it has been operating every single day in my STI since I installed it ... which was about 3 weeks ago.
Tim
Old 09-14-2005, 02:28 PM
Ronny's Avatar
one more. Innovate sells a stainless bung. i believe the one that is shipped is steal. after 1.5 years it seized and threads in 02 stripped.
that connection does corrode but cleans up nice. i put a little dielectric grease on weatherpack connection.
Old 09-14-2005, 04:09 PM
brutalform's Avatar
I always put a dab of antisieze on the threads before I screw it into the bung. Hopefully it will last longer.
Old 09-14-2005, 04:23 PM
Ronny's Avatar
02 sensors can be killed by any foreign substance. i think rtv may be a bad one. if it worked for you that may be a good idea.
Old 09-14-2005, 04:57 PM
brutalform's Avatar
Yea it wont hurt if its the threads only. They ship them new with the antisieze, its just that after having it in, and out alot, it comes off.
Old 09-20-2005, 06:54 PM
RBMZ28's Avatar
Thanks for the info!!!! Ordered o2 and the contraption that holds it in the pipe.(lost on the interstate while testing!!
Old 09-20-2005, 07:22 PM
justlearning's Avatar
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
021906262B part number on that site shows up 62.99 for me??
Elephantismo
02-13-2019 12:51 AM
9192camaro
16
02-03-2019 12:21 AM
antman89iroc
36
01-31-2016 08:42 AM
Scorched1984
09-15-2015 03:42 PM
Quick Reply: wide band o2 sensor replacement
