8625 no datalogging!
Old Sep 14, 2005 | 01:41 PM
Eckin's Avatar
Car: Caprice
Engine: 350 Tbi
Transmission: TH 700
I have recently completed the 747 to 8625 swap using the schematics from this thread. https://www.thirdgen.org/techbb2/sho...hreadid=272975
The adaptor is working, the car is running, i get no ses light and no error codes.
Both tunerpro and datamaster says: aldl cable is working but the pcm is not connected.
I´m using a two transistor cable and an USB/seriell adaptor.
WHat's wrong!
Old Sep 14, 2005 | 03:06 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
The USB to serial adapter is the problem. I tried 3 different adapters and 100's of different settings and could never get one to work. I even tried a PCIMCIA to serial card that didn't work either. I finally gave up and bought a moates USB data logging cable, it works, but I still have a lot of problems with that and datamaster.
Old Sep 14, 2005 | 03:07 PM
justlearning's Avatar
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
if there is a resistor connecting a and b terminal i think u have to disconnect that until starting up then it can be reconnected but im not real sure its been a while since i read about this...do a search w/ my name and i started a thread that links to where i found that info.
John
Old Sep 14, 2005 | 03:28 PM
Eckin's Avatar
Car: Caprice
Engine: 350 Tbi
The USB to serial adapter worked with the 747 and winaldl so i dont think thats the problem
Old Sep 14, 2005 | 03:59 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
The low speed 160 baud is easy enough to get working with any USB-serial adapter.
However, the 8192 requires a 'non-standard' baud rate and as such, most serial usb adapters won't work.
Old Sep 14, 2005 | 07:25 PM
ben73's Avatar
I have successfully connected to this PCM with a moates USB ALDL cable, and a Mastach 9pin serial type. I have tried 3 different usb-9pin adaptors without any luck..
Old Sep 15, 2005 | 05:55 AM
Eckin's Avatar
Car: Caprice
Engine: 350 Tbi
So whats my options? Is the moates usb aldl cable the only thing that works?
I have a 25 pin lpt port on my laptop can i use this in any way?
Old Sep 15, 2005 | 05:18 PM
DM91RS's Avatar
Car: 91 RS
Another vote for Craig's unit..........it works as promised every time.
I have used it with the 8746 tbi /winaldl and the faster 8625/Datamaster.
DM
Old Sep 15, 2005 | 05:39 PM
ben73's Avatar
Yep same here.. Craigs USB ALDL cable is the one you want..
Old Sep 15, 2005 | 09:44 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Has anyone have problems with the craigs USB ALDL cable in datamaster? Mine will record for about 5 min then time out. I have this problem in the beta and non-beta version. I am running a 730.
Old Sep 19, 2005 | 02:13 PM
greenbuggy's Avatar
Car: Take your pick. Probably a '72 Cheyenne/20 or '91 Maxima
Engine: Truck has a 350 W/454 TBI, 350 Injectors, 7747/G2/Atmel
Transmission: TH350...Aint dat a bitch
No problems here logging with a mastach serial data cable on an 8625.
ULTM8Z
Oct 2, 2015 01:25 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
ezobens
Aug 19, 2015 10:29 PM
bamaboy0323
Aug 15, 2015 07:20 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
