LTC 145-150 engine running lean?
Old Apr 15, 2006 | 10:20 AM
vettef6's Avatar
Car: 1992 LT1 Corvette
Engine: 396ci
Transmission: ZF 6 speed
Axle/Gears: 4.10
After changing to a 3“ exhaust system and also switching from an auto to a 6 sp manual trani, my engine seems to bog. It’s as if it were running lean. It’s basically from about 1300 to 2500 in gears 1 to 4. I richened the mixture 5% twice, as it seemed to be running lean; didn’t help any. LTC about 145 –150 and STC about 128.
I used Vemaster exe but all it did was lean out the mixture.
Anyone know what else this might be. I still think I’m running lean!! But Vemaster doesn’t.
Old Apr 15, 2006 | 10:34 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Originally Posted by vettef6
It’s basically from about 1300 to 2500.
That's the area where the converter would still will allow for some slippage.
You'll probably have to add some AE, VE, and reduce the timing.
Thou without seeing you .bin, you might have to do the opposite... Judging by what you said the VE learn said.
Old Apr 15, 2006 | 03:31 PM
vettef6's Avatar
Engine: 396ci
Axle/Gears: 4.10
Grumpy, I was also thinking the converter was covering up the bog. I had a 2400 TC and so it really fits in the range I'm having trouble with.
I was just thinking; if I'm having trouble with this cam, not really a big cam, what do other people do when using a 242/248 or bigger cam????
Since I already richened up the VE table about 10%, I can't think richening up the mixture a little more isn't going to help. I'm going to reduce the timing about 3° and see what happens.
Which one of the AE tables do you mean??
Arnold
Old Apr 15, 2006 | 04:23 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
No the converter wasn't covering the bog, it a matter of you changed the load/ conditions that the ecm has to cope with.
Just more tuning.
Don't think too much, experiment, and take notes, then look for trends.
There are probably 2, one MAP based, and one TPS based. Going from an auto to man means you'll probably want to use less MAP based AE, and more TPS based. Again, experiment....
Old Apr 15, 2006 | 04:45 PM
vettef6's Avatar
Engine: 396ci
Axle/Gears: 4.10
Grumpy, there are 7 AE tables I see:
Accel. Enrich. Vs. Differential TPS (Mult)
Accel. Enrich. Vs. Coolant Temp. (Multi)
Accel. Enrich. Delta TPS PW Factor vs. Asyncr Pulse
Accel. Enrich. Delta MAP PW Multiplier vs. Delta MAP
Accel. Enrich. Delta MAP PW Multiplier vs. Coolant Temp.
Accel. Enrich. Delta MAP PW Decay Factor vs.- Coolant Temp
Accel. Enrich. Delta MAP Enable Threshold vs. TPS
Which one should I change??
One thing to consider is, that just touching the gas pedal (accelarating) a little, and the engine runs okay.
Arnold
Old Apr 15, 2006 | 10:28 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
This is the one that you change to add fuel for a given change in throttle position
This should be the one for changes in MAP. Someone please correct me if I'm wrong, I usually use the TPS table.
Old Apr 15, 2006 | 10:33 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
You got it.
The coolant temp correction is for making huge changes.....
Old Apr 16, 2006 | 09:44 AM
vettef6's Avatar
Engine: 396ci
Axle/Gears: 4.10
Here are the two tables. Can you tell me how much you would change if you were me??
%TPS Multiplier
0.0.... 1.500
3.1.... 1.500
6.3.... 1.313
9.4.... 1.250
12.5.... 1.156
15.6.... 1.094
18.8 ... 1.031
21.9. .. 0.750
25.0... 0.625
28.1... 0.625
31.3 ... 0.625
34.4 ... 0.500
37.5 ... 0.250
40.6 ... 0.250
43.8 ... 0.250
46.9 ... 0.250
50.0... 0.250
KPA Multiplier
0.... 0.125
10... 0.125
20... 0.141
30... 0.172
40... 0.211
50... 0.258
Old Apr 16, 2006 | 09:48 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Try 20% and see what happens.
Like I said, get in there, experiment, and take notes. You can learn more in 2-3 chips, then a full day of posting on a thread. The worst you can do is maybe foul a plug...
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
