32B to 6E works great but no Datalogging?
Old May 7, 2006 | 03:03 PM
PonyKiller87's Avatar
Car: 87 Iroc Z28
Engine: 355 TPI
Ok I have 165 ECM and I was running the stock 32B ABWN bin. After another post on here I used the autoprom and burnt a 6E bin and stuck it in the G3 adapter with the stock Memcal on it. The car runs awesome but I can't get it to datalog using the 32b or the 6E ADS file in TunerPro. So do I need to find a 6E memcal so that its the same as the Bin Im running to get the data loging to work in the 6E ADS file? Also, how do I know which position to have the data logging switch on the Autoprom, I tryed it in all three and none worked.
Old May 8, 2006 | 11:38 AM
87 Vette Owner's Avatar
Car: 1987 Corvette
Engine: 383 ci
Transmission: ZF 6 Speed
Axle/Gears: 4.10 Dana 44
Good question - which ADS (ALDL definition file) should be used in TunerPro RT when the conversion from $32B to $6E has been done? I'm actually at this stage now.
Did you set up Tuner Pro to use "AutoProm" as the datalogging device type?
If you are datalogging (or trying to) using the AutoProm / TunerPro combo, I believe the horizontal switch needs to be towards the USB port, and the vertical switch needs to be in the top position for the 10k resistor used with the 165 ECM ALDL interface.
Old May 8, 2006 | 12:05 PM
Car: 87 Iroc Z28
Engine: 355 TPI
Yup, I got all that and I actualy got it to give me the blue window saying that it connected. But I still wasnt getting anything, the dash was all 0.0 and none of the other things had readings either. I will try to mess with it more this week if I get time.
Old May 8, 2006 | 12:09 PM
Car: 1987 Corvette
Engine: 383 ci
Keep me posted - I definitely want to know how you make out!
Dan
Old May 8, 2006 | 12:53 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
I don't beleive there is anything in the memcal that would prevent the datalogging from happening(other than the code). The aldl operation will follow the mask, so you should use the 6E if the code was changed to 6E.
Old May 8, 2006 | 12:55 PM
Car: 87 Iroc Z28
Engine: 355 TPI
Thats what I was hoping for because the ADS file for the 6E is way better. I think when I did get it to connect I was running the 32B so maybe thats why I didn't get anything.
Old May 8, 2006 | 04:33 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
When running $6E, use the 1227165_6E.ads file included with TunerPro. If it doesn't connect the first try and you're sure your ALDL settings are correct, then hit connect again.
M
Old May 8, 2006 | 04:43 PM
Car: 1987 Corvette
Engine: 383 ci
M
Thanks Mark!
Dan
camaro87-alex
Mar 17, 2011 12:05 PM
dyeager535
May 17, 2009 12:16 AM
85DropTopTA
Sep 10, 2007 10:13 AM
im
Aug 8, 2007 02:50 PM
okfoz
Jul 3, 2001 07:26 AM
