ZZ3/ZZ4 guys.... what chip do you use???
Old Sep 24, 2000 | 01:56 PM
89IROCZ
Guest
Posts: n/a
I have an 89 IROC-Z with the L98 in it right now. I own a ZZ3 on the side, and I am considering dropping the ZZ3 in my car again. Now, what chip do you use? Do you need a custom burned chip, or will a performance resource chip do the trick?
Let me know.
1989 IROC-Z
350c.i. TPI
rebuilt 700R4 with shift kit
3'' Monza Pacesetter cat back exhaust (minus the muffler)[SOUNDS OF THIS ON MY WEBPAGE]
new dual cats
3.23 Posi rear
hypertech chip
under drive pulleys
adjustable fuel pressure regulator
K&N Air Filters
Excalibur alarm, keyless entry and remote start
new:
struts, shocks, bearings, distributor, cap, rotor, alternator, battery, regulator
245 ZR16 50 Tires, Rotors and brake pads all the way around
Go to my webpage to find out more about it.
You can also see pictures, and hear sounds as well.
http://go.to/iroc-z
AOL IMer: JRShotliff
Old Sep 24, 2000 | 03:05 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I think the stock chip will work fine, or the PR chip. I'm using a stock 305 5-speed chip in my 350 engine with ZZ4 cam and heads. The ZZ4 cam has a mild enough intake duration that the computer can handle it.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 24, 2000 | 04:38 PM
Blade's Avatar
Kevin... why is that chip better then the stock 350 chip ??
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Old Sep 24, 2000 | 06:52 PM
89IROCZ
Guest
Posts: n/a
Kevin,
I am not flaming by any means.... but wouldn't common knowledge tell you that if you are running 13.25 in the 1/4 with a stock 305 chip in your modded 350, you would probly do even better than that with a stock 350 chip, PR chip, hypertech chip, etc?????
Old Sep 25, 2000 | 02:05 AM
Kevin91Z's Avatar
Because they dont make a stock 350 5-speed chip, so I'm stuck with the 305 5-speed chip.
And I shouldnt call it stock, because its a custom burn from Turbo City. But the closed loop values are stock. The only thing changed is the WOT fuel and timing tables. We've been experimenting with it over the last 6 months trying to get the chip dialed in at WOT. I think we finally got it, but I havent had a chance to make any good runs at the track.
Old Sep 25, 2000 | 08:32 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Kev,
Check to to see how much knock retard you get. The ESC filter (knock module) on the CalPak is different for 305s as compared to 350s (730 ECM).
BTW - You can convert a 350 auto chip to a 350 manual. I have heard of a couple guys who have done it. I can try to find out the destructions on how to do it if you are interested ... or, you could post to gmecm.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.587 @ 107.97mph (1.710 60ftr) on the long runner setup.
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels. Stock Wheels. No Weight Reduction.
Gunning for NA 11's with the MiniRam II and Hooker LT Headers.
Moderator: PROM board at thirdgen.org
Old Sep 25, 2000 | 12:06 PM
Kevin91Z's Avatar
According to Diacom I get 0 to 1 degree of knock retard after adding in NOS Octane Booster, at a total of 35º advance. My next thought would be to change the value in the chip from 305 to 350 and see what happens. The only reason we didnt was because the fuel tables were almost dead on when we started, and only the timing had to be changed.
Old Sep 25, 2000 | 03:52 PM
89IROCZ
Guest
Posts: n/a
Kevin,
I completely did not think of that... (that=no such thing as a 350-5speed stock combo).
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
