Will a 1987 TPI prom work in a 1988 computer??
Old Nov 20, 2000 | 02:20 PM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
I am switching to TPI and I have a complete wiring harness and computer from a 1988 350 TPI. My car is a 305 5-speed and what I would like to know is were there any differences in the computer system from 87-88 and will a 87 5-speed TPI prom work in a 88 auto 350 computer. Thanks
Dave
Old Nov 20, 2000 | 03:56 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Dave
From the name of the formum, I *expect* that you'll be doing your own ships in which case using the 89 code / memcal, would be where to start. Buy the right memcal (calibration piece) from the dealer for the closest place to start.
You might ask here for that praticulars on doing that,
Old Nov 20, 2000 | 04:35 PM
Car: 1992 Camaro
Engine: 350 miniram
I am not burning my own, but this forum seems like the best place to ask the question. This is a stock prom from a 1987 TPI 305 5-speed, and the computer is from a 1988 350 auto. I would like to know if the chip from the 87 will work in the 88 computer or if I will need a 1988 chip, or if I will need a whole new computer and chip.
Old Nov 20, 2000 | 07:08 PM
Brent's Avatar
You can use your 87 TPI memcal in the 88 TPI ecm. 86-89 Fbody TPI all use the same 1227165 ecm.
Refer to: https://www.thirdgen.org/newdesign/f...n.shtml#engine
Old Nov 21, 2000 | 12:47 AM
Car: 1992 Camaro
Engine: 350 miniram
Brent, First off thanks for the link to that page, that was really nice to see.
I am looking at my new computer and the
ECM# 1226870, could you please tell me what this computer is from. I thought it was from a 1988 TA 350, but my number is different than the one you gave. Any insight into this would be greatly appreciated.
Dave
Old Nov 21, 2000 | 12:51 AM
Car: 1992 Camaro
Engine: 350 miniram
Well upon futher investigating, this computer is from a 1985. So my new question is, Can I use this computer with a 1987 TPI prom??
Old Nov 21, 2000 | 07:56 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Nope, won't work. Even using a manual-tranny chip in an auto-tranny car isn't a good idea. Trust me, I tried it by accident already. Grumpy's suggestion of using a stock chip for that application is the best way to go if you're not burning your own chips.
Greg Westphal
'87 IROC 305TPI/A4
Old Nov 21, 2000 | 10:03 AM
87Z-ya's Avatar
Dump the 85 computer it sucks....
87z 383,afr 190's, crane hyd roller(224/230-.509/.528,112 sep),Ported and polished mini ram, 24lb inj, 3.42 gears, strange 12 bolt, tremec 5spd, , 1,3/4" slp headers.(stock 305 hypercrap chip), other stealth goodies.
Runs 14's all day long.
Old Dec 10, 2000 | 04:51 AM
Matt_Ky's Avatar
Car: 1998 Camaro Z28
Will a 1985 TPI wiring harness work with 86-89 ECM's?
thanks
Old Dec 10, 2000 | 07:04 AM
BOWTYE8's Avatar
The 85 ecm will work with some harness modification but its just not worth it at all. The 85 has a maf burn off module(expensive) and the 86-89 have burn off relays.
I would suggest goto the junkyard and get the 165 ecm shouldnt be more than $50
The 85 ecm just isnt worth it. not good for and kind of scan data.
Denis
85 vette,383,miniram,ZF6,4.10's..best ET 11.66@1187.00 60' 1.62
w/100HP nirous 11.05@127
http://geocities.com/bowtie8
Steven 86IROC-Z
May 24, 2026 04:52 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
beachrodder
Aug 25, 2015 08:05 AM
jharrison5
Aug 19, 2015 05:53 PM
djmarch
Aug 11, 2015 10:22 AM
