Eprom Stuff/parts
Old Apr 12, 2001 | 11:19 PM
BenDoe's Avatar
Eprom Stuff/parts
Does anybody know where i can find a GM female serial diagnostics port connector ODB1, also where are the cheapest prom burners? And on the side, what is the ballpark estimate for how much HP can be gained from this stuff?
1991 Z28 305 5spd 1LE, TES headers, dual cats, 3 Chamber flowmaster, Comp cams .488/.495 212/218 the usual street racer with a stock chip.
Gained 20HP by porting and polishing my EGR passage.
Old Apr 13, 2001 | 01:35 AM
Synergy's Avatar
For a female port... go to the junkayard and yank one off any 80's GM car (almost).
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car.
Check out our car club Truspeed
Check out the Bin Archive for all your .bin needs
Old Apr 16, 2001 | 11:18 PM
BenDoe's Avatar
sorry, i meant the male connector, where can i get a male connector?
Old Apr 17, 2001 | 01:37 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Check out the Auto Xray 20110 cable.
It'll set you back $20-30 but it's
what you're looking for. I don't have
a cheaper source; anyone?
Old Apr 21, 2001 | 04:37 PM
BenDoe's Avatar
does anybody have a website for that?
Old Apr 21, 2001 | 05:28 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
See it at OnTool <A HREF="http://www.ontool.com/store/product/5045">http://www.ontool.com/store/product/5045</A> for $24.95 or <A HREF="http://www.summitracing.com/">Summit</A> for $27.99 (search for Summit part AXY-20110).
Old Apr 21, 2001 | 05:36 PM
BenDoe's Avatar
Will that cable plug directly into a laptop and make it able to run some of the free software that tells you how your engine is running?
Old Apr 22, 2001 | 09:07 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
No. That's the end you were looking for; you then cobble it together to work with the ALDL circuitry you can build or buy from AKM electronics.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
the_nikfive
Aug 11, 2015 02:46 AM
Grim Reaper
16
Jun 14, 2002 05:20 AM
a73camaro
Feb 20, 2001 03:20 PM
doc
Feb 13, 2001 01:58 PM
