Win Bin ecu file
Old Apr 23, 2001 | 11:39 AM
87ColdAirIroc-Z's Avatar
Win Bin ecu file
I have questions on ecu files i have a 87 iroc tpi and was wondering if i only need 1 ecu file or more and does any one know where to get one?
87 Iroc-Z LB9
Dynomax exhaust
modified MAF & airbox
3-10" JL subs
Eclipse components
Old Apr 23, 2001 | 12:03 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
You need the ECU file for your particular ECM/prom ID combination. You have a '165 ECM and likely a $32 ID software.
A recommendation is to upgrade to the $6E code and use a .ecu file for that, found on the third gen yahoo groups page.
Old Apr 23, 2001 | 06:08 PM
If i were to upgrade to a $6e code how would i do it??
Old Apr 23, 2001 | 06:49 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
You'd download the ARAP.bin file, modify it to match up with what your car is, burn it on a PROM and install it in your car. You can use the 89v4.ecu file that's available on the third gen yahoo site to run winbin, in order to modify the ARAP.bin file.
This way you get to ditch the 9th injector and run code that's a little more refined.
Old Apr 26, 2001 | 02:46 PM
Will my stock computer be able to read the $6E code? Or do i need to replace that also?
Old Apr 26, 2001 | 03:21 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
'86 - '89 F-bodies used the '165 ECM and you should be able to run the $6E code in your ECM with no other modifications.
Old Apr 26, 2001 | 07:04 PM
Scott 87 IROC-Z's Avatar
Car: 87 IROC-Z28
Engine: 377ci, Brodix Heads, Solid Roller c
Transmission: 700-R4 w/ Yank ST3500 Converter
Don't forget the unplug the connection to the cold start injector though.
87 IROC-Z 305 TPI gears, exhaust, converter
14.70 at 94.1 mph
Minirammed 377 for spring
Old Apr 26, 2001 | 07:54 PM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
<font face="Verdana, Arial" size="2">Originally posted by afgun:
</font>
Question:
What is the "third gen yahoo site" which you are referring to? I went to Yahoo and searched for "third gen site" and didn't find one. I don't understand....please enlighten me
Old Apr 26, 2001 | 10:16 PM
james_fearn's Avatar
http://groups.yahoo.com/group/3rd-gen/files/
James
Old Apr 26, 2001 | 10:45 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Did ole Eric Aos ever fix WinBin? I remember having some serious issues w/r/t the 16-bit values that were less <= h$0FFF as of v0.14. The 89v4.ecu file referenced above is the best one we put together for the ARAP, but I think it is still subject to this problem, which will rear its head when you go to set the rev limiting and such, the fuel injector sizing too. If anyone knows different, let me know, but it was kinda crippled there for a while. Mostly it's great, just a couple snag-points.
Old May 7, 2001 | 09:17 PM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
<font face="Verdana, Arial" size="2">Originally posted by Craig Moates:
Did ole Eric Aos ever fix WinBin? I remember having some serious issues w/r/t the 16-bit values that were less <= h$0FFF as of v0.14. The 89v4.ecu file referenced above is the best one we put together for the ARAP, but I think it is still subject to this problem, which will rear its head when you go to set the rev limiting and such, the fuel injector sizing too. If anyone knows different, let me know, but it was kinda crippled there for a while. Mostly it's great, just a couple snag-points.</font>
Old May 7, 2001 | 09:20 PM
ooops!!!!!
Yeah, he never fixed it. It drove me crazy. Maybe some one should let him know.
'91 Formula
383CI Supercharged
5-speed
3.42
12.34@117.04
on Drag Radials
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
KO1
16
Oct 15, 2015 05:00 PM
Linson
Sep 21, 2015 01:08 PM
