What I've been working on - ScannerPro
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Hi Guys -
I'm thinking it's time to explain the delay in new TunerPro builds. I've set TunerPro aside for a bit to focus solely on datalogging and monitoring. The result is a new piece of standalone OBD monitoring software with all new features. I've written this application from scratch and developed it with the lessons I've learned in writing TunerPro in mind.
It uses a new definition format, ADX, that shares many features with XDF. Items can be linked to other items (for new data types such as economy, fuel correction terms [target AFR/WBO2], etc). You can define constants for other calculations (injector flow rate, vehicle weight, etc).
You can gather histogram data, with a definable history depth and various calculation methods including standard deviation, running average, historical average, etc. The active cell is highlighted.
The dashboard is completely configurable, with new controls (including an analog gauge) and more planned. You can add as many gauges as you want and place them where you want them.
The monitor control has been rewritten from scratch. A monitor can have as many plots as you want. Log data will be populated on load. You can add as many monitors as you like.
Item lists are completely confurable. You can add flags and values to the same lists, and define multiple lists. List text can be any color you choose with bold font or regular.
Value data can be passed to lookup tables, and lookup tables are now much more powerful. You, can for instance, define a string lookup table with "Cold, Warm, Hot, Overheating" and associated values and pass the output of a coolant temp item to said lookup table. The string closest to the corresponding value outputted from the item will be displayed.
Commands can be batched in macros for doing things such as data dumps, complex connection routines (such as those required for $58 - my current testbed, and 94/95 LT1). Down the road you can also define BIN dump macros for ALDL bin dumping, as well as control commands for doing Mode 4 stuff.
Once I get it to a logical milestone, all features of ScannerPro will be integrated into TunerPro RT.
I have tons more work to do on this, but figured it's a good time to announce what's coming. I won't be able to get all my ideas in before release (I've been working on it for ~6 months as it is!), so there will be a lot of things added after release.
All of this will eventually lead me to auto-tuning.
I plan to have a beta available for people to play with in a couple weeks (2 if all goes well).
Here are some screens:
The dashboard
Histograms:
Item lists:
Monitors:
The ADX definition editor:
The dashboard
Histograms:
Item lists:
Monitors:
Transmission: T5WC
PS - Notice there is no application icon in the caption bar. If you're the artistic type and want to make your mark, I could use your help in creating an application icon for ScannerPro. The icon should support all normal icon sizes (16x16, 32x32, 48x48, etc). If this is something that interests you, please contact me offline.
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
WOW!!! Don't have to much to say but WOW
I really like Tuner Pro and this is just what the doctor ordered. I will love the fact that it should be able to handle $58 masks. I am assuming through Autoprom with real Time Emulation right?
Another Great piece of software in the makings.
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Very nice
I'm available for Beta work if needed on 98SE, 8D, AutoProm.
Can work to create the definition if an importer is not implemented yet.
Transmission: T5WC
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I'm available for testing as well, Mark: 7730, 8D, Ostrich, currently the "lead" (only last I heard) S_AUJP v4 tester on a daily driver (not a test bench) for Scott and JP.
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
you just keep coming up with better & better ideals, you are the man Mark
i can help test it too if needed.
desktop is a P4 2.4 533 512 megs ram windows XP pro.
primary laptop is a dell 600 P3 1.0 384 ram windows XP pro.
backup laptop is also a dell 600 P3 1.0 256 ram windows 98SE.
AutoProm 730 8D
AutoProm 730 8D
I was going to wait for someone to bring it up but...
How are you displaying the VE value on that screenshot
I'm running S_AUJP_V3, SD 7730 ECM on HSR 383 with Holley 52MM throtllebody, Comp Cam 224/230 (with 1.6 rockers .536/.544 at .050) on a 1991 Firebird
Laptop IBM 380D Pentium II 300 running Win2K (currently using Tunerpro)
I'm trying to tune my car now, so if you're looking for more beta testers, I'm in!
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
I'd like to buy a copy as soon as you release it.
A combined program for OBDI is awsume!
Thanks Mark!
Thanks Mark!
Car: 1997 Jeep Wrangler
Engine: 2.2 L61
Transmission: R150/AX15/Toy T-case
Axle/Gears: 5.29
Awsome work Mark !!!! I can't wait to give it a try... I finally got my fuel pressure problem sorted out so the timeing for this is perfect !!
Car: 69 Camaro
Engine: LS1 converted to LS6
Transmission: 4L70
Axle/Gears: 12bolt 3:42
Mark looks great. Are you gonna work on some self tuning stuff also? I know you were talking about it a few years back. EFI live has one for OBDII stuff that supposedly works pretty good....
Transmission: T5WC
I'm anxious to see that as well.....
1 Post
Car: 1991 caprice / 96 caprice
Engine: 4?? bbc / lt-1
Transmission: 700r4 / 4l60e
Axle/Gears: 4.10/ 3.73
i would love to test it out on a 16136965 with a $62 mask but im still have not been able to find an .xdf for it yet.
Transmission: T5WC
Hi Guys -
Sorry for the lack of response on my part, and thanks for the wonderful interest (it's what keeps me going!).
I've been away on vacation for a week and have been swamped at work (it's that time of year).
I will put together a setup with some simple definitions for the common platforms that should allow many of you to play around. I will have ZERO documentation to start with, so I'll be relying on some self-driving and knowledgable users to play around and figure things out.
Look for an update in the next few days.
Thanks again!
Mark
Thanks again!
Mark
Car: 84 Vette
Engine: 383 XFire
I am in for testing. I have a immediate need for more data coming from a 8746. I am helping a friend getting his 383 running in his 84 Vette. His cam is much more aggressive than mine which has made things challenging to say the least.
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
I see some other people are behind times like me on their laptops. Is this gonna be compatible with Win2K, 98Se and etc.?
Last year or so ive been running into (64bit?) problems on older OS and newer programs.
Great thing though and thanks.
Transmission: T5WC
Yes, it is compatible with everything except Win95, just like TunerPro. ScannerPro will be a bit more system intensive than the current incarnation of TunerPro, though. A minimum of a 266mhz will be necessary (probably), with 400mhz or better recommended. This may improve in the future, or it may not (afterall, it is 2006, so IMO it's time for the lowest common denominator to improve).
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
165 here and I wouldn't mind being a guinea pig... 165 is pretty common I would say....
Car: 69 Camaro
Transmission: 4L70
I had a short datalog and manually edited my VE tables -again yesterday. When you going to let us have this thing. I am almost ready to do a VE table spreadsheet to do the averages. I am soooo tired of doing this stuff by hand.
Transmission: T5WC
Sorry for the delays guys. Work on this has been moving at a snail's pace. Unfortunately my day job is taking its toll on my time. Things should slow down in the next few weeks (I should have something to you before then, though).
I'll keep posting updates as I get closer. I'm not far from having something for you all to play with (I swear!). In fact, some have already been using it.
Car: 1993 Pontiac Grand prix
Engine: 2.8/3100
Transmission: 4T60-E
heh me too
id love to test this out...
will ads files be importable ?
or will we have to create new ones, no biggie if we do should only take like half hour hehe
Transmission: T5WC
Alright Gomers...
Thanks for all the interest. I'm not really ready to release anything, but I'm going to anyway.
Click here to have at it!
Note that there isn't much to the site at the moment.
I'm calling it a beta, although I'm nowhere near where I want to be. I figure, though, that it's time for you guys to start playing around. Please read the little "agreement" carefully before downloading. I have zero documentation at the moment, but the included ADX files should be example enough to get many of you started.
You will undoubtedly have questions. For that I've created a "ScannerPro Application" group in my TunerPro forum. Here's a direct link to the ScannerPro beta discussion forum:
TunerPro User Forum :: View Forum - Beta Discussion
I'll try very hard to keep up with your questions there.
Oh, and I'm going out of town for 5 days or so, so I'll be a bit slow to respond at first.
Have fun!
-M
Have fun!
-M
Engine: 2.8/3100
lookin good so far
anyone figure out how to add bitmasks yet ?
not the same as tunerpro rt aldl editor
for the bits you put in operation, operand ?
bit
0 = 0x01
1 = 0x02
2 = 0x04
3 = 0x08
4 = 0x10
5 = 0x20
6 = 0x40
7 - 0x80
how does one get the proper addresse
bit
0 = 0x01
1 = 0x02
2 = 0x04
3 = 0x08
4 = 0x10
5 = 0x20
6 = 0x40
7 - 0x80
Transmission: T5WC
See my response to your post in the ScannerPro forum.
Okay, I registered on the forum site but it I didn't receive my email to confirm the registration. Can you resend the email again? The login ID is the same as the one here.
#42
Car: 1983 G20 Chevy
Transmission: 4L60
I have started working on Definition files with Dashes, Histograms, etc, for both 1987-1991 TBI trucks and 1994-1995 Automatic TBI trucks.
#43
Transmission: T5WC
#45
Anbody willing to help an old phart get scannerpro to connect? Didn't get any replies on their forum today so asking here. PM's are fine, so is email
#46
Car: 69 Camaro
Transmission: 4L70
Anybody started working on a 730 $8d scan yet? JP, Scott, anybody? I've been distracted working on suspension mods and not driving the car. Maybe a collaboration on this to get to a good working definition on this.
PS BTW Mark love the ScannerPro logo/pic on the website....
#47
Transmission: T5WC
An 8D definition is in the download. That should get you started, I think.
Vern - what year/ecm/mask? If you have an ADS for TunerPro, you can import that into ScannerPro.
#48
Car: 69 Camaro
Transmission: 4L70
OK. I didn't know that you can now use a ADS definition to import to start. I will try that maybe as soon as this weekend....thanks Mark I can't wait to see the intergerated solution.
#49
OK, I'll check it again. I'm using $8D with S_AUJP v4 beta in a 730 (91 'Bird in my .sig). I had imported my ADS file, and that appears to have worked, but it's probably stoopitity (LOL) on my part not knowing what to hit to connect. Little connect button says not connected when I try that.
#50
Car: 69 Camaro
Transmission: 4L70
I'm running V? something but I lost track and have not heard from Scott or JP in a while. I was chasing gremlins on my cold start idle. It appeared that my IAC was not working but it actually was. I don't know if it has the 'manual' bin idle stuff in it but I used to be able to open my blades and watch my IAC counts go down immediatly. That wasn't happening. I finally said f@#k it and opened it. After a while the counts went down to about 30 which is where I like it for split blm. I am not sure if this was caused from the LT1 intake or something else.
