EEPROMS and Pocket
Subscribe
Jul 2, 2001 | 07:02 AM
Can Pocket Programer be used for the 29C256s?. I have version 3.55 and don't see it listed. Any clues if it's just software, or hardware?. Weren't they taken over by a new firm, anyone have a phone number, and contact off hand?.
TIA
Reply 0
Jul 2, 2001 | 07:32 AM
Yes. Many of us here are using the AT29C256 chips with the PP. Its a software issue. You'll need to pay them to upgrade to the latest software IF you don't have the AT29C256 option available. However, with the DOS version you have to press ANOTHER key on the EPROM list to get ANOTHER list of PROMs. ALSO, EPROM.exe does not do EEPROMs. Only FILEPROM.exe does EEPROMs. The windows version of their software also does the EEPROMs.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Reply 0
Jul 2, 2001 | 08:38 AM
As Tim said, use FILEPROM, then select "F" for Flash and then option "8" for the AT29C256. I too have version 3.55.
Reply 0
Jul 2, 2001 | 09:10 AM
I am using ver 1.13 for windoze and it has a date of ( 12 June 2001 ), it programs the AT29C256-90PC perfectly, not a problem at all.
John
87 Formula Yellow/Black
Engine & Transmission
.040 over 5.0 converted to TPI, 9.5:1 Compression, SLP Cam Dur 206/212, Lift 480/487, Cent Line 112, SLP headers, SLP cat-back exhaust, K&N Airfilter, Modified Stock cold air intake, Ported & polished Stock TPI intake, Holley Adjustable Fuel Press regulator, AC Rapidfire Spark Plugs.
Gil Younger (no yo-yo) Shift Kit, Aluminum Driveshaft, 3.73 Posi gear
Suspension & Brakes:
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Hotchkis strut tower brace, South side machine frame connectors, Custom reinforced control arms and pan hard bar.
Interior:
Custom Leather interior, CUSTOM Yellow Gauge Faces, Kenwood Receiver, Pioneer Speakers, Kicker Substations, Kenwood 10 Disk Changer, Pioneer Amp.
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Reply 0
Jul 2, 2001 | 05:34 PM
Quote:
<font face="Verdana, Arial" size="2">Originally posted by Glenn91L98GTA:
As Tim said, use FILEPROM, then select "F" for Flash and then option "8" for the AT29C256. I too have version 3.55.</font>
OK, got that covered now,
now,
How do you actually erase them?.
TIA
Reply 0
Jul 2, 2001 | 06:30 PM
With my old Toshiba, and FILEPROM 3.55, I found that "initializing" with a BIN of Hex FFs first and then I could program the BIN I intended on it.
Without the Hex FFs first, the PP would program it fine, but my ECM didn't like it. With the Windows Version, this "initializing" with Hex FFs is not necessary. Just load the new BIN right on top of the old one and all is fine. Unfortunately, my ol' Toshiba does not like the Windows Version. The Compaq is fine.
Reply 0
Jul 2, 2001 | 08:46 PM
</font>
So erasing it just means programming it with all FFs?
Yes, I'm limited to using the DOS program.
Reply 0
Jul 3, 2001 | 08:12 AM
Yes. After loading it with Hex FFs, it should check out as "blank". I believe this is just a querk of version 3.55. I've been told that you don't have to do this with 3.60, but I cannot confirm as I do not have that version.
Reply 0
Jul 3, 2001 | 01:55 PM
From my experiences, You don't HAVE to blank the flash chip with FF's. I do it sometimes just so i can convince myself its blank and so that i can use the cool blank check option on the flashprom.exe
Best thing to do, just program the chip, then do a check on it with option number 3.
Brendan
Reply 0
Jul 3, 2001 | 02:48 PM
I have never blanked the chip first.
Tim
Reply 0
Jul 3, 2001 | 06:02 PM
Quote:
<font face="Verdana, Arial" size="2">Originally posted by TRAXION:
Tim
</font>
Tim, is that with FILEPROM Version 3.55? I know the Windows Version does not. It seems only to be an issue with FILEPROM V3.55 with my setup. And ONLY when I use the Flash Prom in the ECM; reads fine, just my ECM doesn't like it.
Reply 0
Jul 4, 2001 | 09:59 PM
Glenn,
Just the WinDoze version.
Tim
Reply 0
Jul 4, 2001 | 10:28 PM
I DO LIKE the Windows Version very much. I just wish I could get it to work properly on my Toshiba.
Guess I COULD buy another notebook. (Thunk ... as the wife hits me with a frying pan).
Reply 0
Jul 5, 2001 | 07:29 AM
ROFL at that frying pan comment
Tim
Reply 0
Subscribe
