Adj. Fuel Psi Regulator..NO vaccume line??
Old Oct 16, 2001 | 10:12 AM
ptc92rs's Avatar
Has anyone ever seen an adjustable fuel psi regulator for a TPI system without a vaccume line? My shop manual talks about it when adjusting the fuel psi but I dont have one. There is just a small hole in the side of the case above the diaphram and nothing else except the adjusting screw. This regulator appears to only sample atmosphere. Is this going to be a problem? All I know about this TPI setup is that I dont think its a factory model, and it says "Big Mouth" on the intake.
'92 RS 350 Big Mouth TPI 5spd 2.73 lmtd slp Daily Driver with "ISSUES"
Old Oct 16, 2001 | 10:26 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by ptc92rs:
</font>
Is it used?.
Possibly broken?.
Been to 3 county fairs now, and at all 3 they had vac ref ports (3rd gen TPIs anyway)
Old Oct 16, 2001 | 11:06 AM
ptc92rs's Avatar
It doesnt appear to be broken, no marks. All I know is its what was on the car when I got it.
Old Oct 16, 2001 | 11:16 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
</font>
IF, it were mine, I'd be drilling it out and installing a piece of brass tubing in there.
TPI, right?. Just never saw that before.
Old Oct 16, 2001 | 11:47 AM
fast_broker's Avatar
Grumpy is right. I'd bet that little hole was once a nipple with a hose attached to it... heee heeee
Old Oct 16, 2001 | 02:14 PM
new2tpi's Avatar
My FPR is billet aluminum with a (very small) tapped hole for the brass nipple that came with it. Can't remember the brand. Can you tell if the hole is threaded?
Old Oct 16, 2001 | 07:44 PM
ptc92rs's Avatar
Did not appear to be threaded. Maybe it once had a press-in fitting. ????? The worse part is I'm not sure I can even get to it with out taking the plenum off.
Old Oct 16, 2001 | 08:49 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Its broken. It should have a nipple on it that is connected to a vacuum source. Look at the underhood label. It will have the vacuum diagram.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Oct 16, 2001 | 08:58 PM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
You will definitly have to remove the plenum. On my fpr it had special torks screws that I had to get a tool for. The torks screw has a little nipple in it. The torks bit will have a hole in it to slip over the nipple.
Old Oct 16, 2001 | 11:27 PM
ptc92rs's Avatar
No diagram, this car came with a TBI. Im guessing it should be T'd into the plenum? Does the regulator get atmosphere psi at all? What I'm saying is does the vaccume on y'alls cars go above or below the diaphram and atmospheric psi on the other.(like a booster type diaphram) Option #1: Fuel psi and MAP on one side of diaphram vs. atmospheric psi and spring on the other? or Option #2: Fuel psi on one side vs. MAP and spring on the other?
fasteddi
Sep 2, 2015 10:29 AM
mdtoren
Aug 23, 2015 12:52 PM
wayshegoes
Aug 17, 2015 12:00 PM
mdtoren
Aug 16, 2015 05:45 PM
Kaweh
Aug 9, 2015 02:54 PM
