tach rpm vs datasmter rpm?
Old Jun 24, 2007 | 03:44 AM
devilfish's Avatar
tach rpm vs datamaster rpm?
the tach shows about 400rpm more then datamaster. Is this common? What should I rely on?
Old Jun 24, 2007 | 09:21 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: tach rpm vs datamaster rpm?
Yes, it is common for the tach's to display a higher reading. I trust the ECM value more then the tach.
RBob.
Old Jun 24, 2007 | 09:51 AM
trackbird's Avatar
Car: 1991 Corvette
Engine: 353 cu in
Transmission: M6
Axle/Gears: 3.45
Re: tach rpm vs datasmter rpm?
I've got a 1992 Z28 with a tach that's showing to be farther off than that. When I shift at 6500 rpm, as indicated by the tach, the computer is only showing 5,930 or so. I'm just going to install a shift light and set it 200 rpm below the rev limiter for now. I'll deal with the tach later (or remove it all and go aftermarket, this is a track car).
Old Jun 24, 2007 | 11:00 AM
Gary Anderson's Avatar
My '90's tach reads about 10% high.
Old Jun 24, 2007 | 04:19 PM
devilfish's Avatar
thank you
Old Jun 24, 2007 | 10:39 PM
trackbird's Avatar
Car: 1991 Corvette
Engine: 353 cu in
Transmission: M6
Axle/Gears: 3.45
I installed an autometer shift light tonight and with the 3,000 rpm test chip, I had to reach 3,500 on the tach to get it to light up. I'm going to assume (maybe incorrectly) that autometer isn't going to screw up a shift light and risk someone blowing an engine, so I am thinking the tach in my car is truly that far off.
Old Jun 25, 2007 | 03:48 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
My AutoGauge tach and my digicon have NEVER agreed on what the engine RPM is, the digicon is actually about 500rpm higher than the tach; when I first hooked it all up and set the shift light it would hit the rev limiter before the shift light would come on.
Old Jun 25, 2007 | 05:25 PM
devilfish's Avatar
hmm strange. How hard can it be to build a working tach on a production car?
well. Thanks for the heads-up m8s.
Hotrodboba400
Dec 10, 2019 07:07 PM
86maro_252
Oct 10, 2015 06:52 PM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
