EBL RAMJET dying after idling for a while
Car: 92 RS Convertable
Engine: RAMJET 350
Transmission: G-FORCE T-5
Well just got my car running. Wow this thing sounds awsome. Done about 10 VE learns on it, running much better, has about 25 miles on the new build. Mods in sig.
Current problem is that if it idles for a while the BLMs shoot up and the car dies and can't restart untill after it cools. No idea what is causing it?
Any help would be much appreciated
Also if anyone wants to look at my bin and data log and tell me where to go next that would be great also
Thanks in advance
Ryan
Thanks in advance
Ryan
Car: 1983 G20 Chevy
Transmission: 4L60
Re: EBL RAMJET dying after idling for a while
Thanks in advance
Ryan
Thanks in advance
Ryan
Car: check
Engine: check
Transmission: check
Fast355 hit the nail on the head with the O2 sensor cooling off. After about 3 minutes of idling the O2 value starts dropping off. The INT & BLM starts adding a lot of fuel which floods the engine.
For now can set the open loop idle option to prevent the issue. Option Word 1, OpIdl.
RBob.
RBob.
Engine: RAMJET 350
Thanks for your help, I'll give that a try. Still a little confused on how that happnes, it took 20 min of sitting there idling for it to stall (only posted the last few minutes of the log) would a heated O2 sensor help?
Thanks again for your help
Ryan
Ryan
Engine: RAMJET 350
or why I can't restart it for a while (over 30 min) after it stalls?
Thanks again
Ryan
Thanks again
Ryan
Car: check
Engine: check
Transmission: check
From what I could tell a heated O2 is required. How far down the pipe from the heads is the O2 sensor?
The stalling was caused by the engine flooding. Note the injector PW as the INT & BLM's increased. If it happens again hold the pedal to the floor while cranking. That invokes a clear flood mode.
RBob.
RBob.
Engine: RAMJET 350
the O2 is in the drivers side shorty headder, just foward of and at about the same height as the middle of the oil filter
I'll try a heated O2
thanks
Ryan
thanks
Ryan
Car: 1983 G20 Chevy
Transmission: 4L60
It would be easier to just turn on open loop idle for the experiment. I think the cam in your engine will idle better in open loop with a slightly richer a/f mixture anyway.
