ses and security
Old Jun 8, 2008 | 08:23 PM
vette9190's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
ses and security
Ok so I did the TPI swap On my 91 RS. It has vats on it. I wanted to eliminate it so I bypassed the starter enable relay. I then pulle dmy chip(ANHY) and pulled the bin down to my pc I disabled vats and that is all I did. I put it in and everything was fine. I then wanted to update to the S_AUJP bin but wanted to compare the 2 bins to see how much was different. So I pulled the chip back out of the ecm to get the bin again(hard drive that had it crapped out) I put the chip back in and now i get the ses light and security light on all the time. The car will start but dies out right away WTF? did I fry the ECM or something. I disconnected the battery and grounded myslef . I work with electronics for a living so I know how to handle them. I also work with IC chips regularly so I'm pretty sure I inserted the chip properly. Anyone got any Ideas? HELP!!!
Old Jun 10, 2008 | 12:59 PM
vette9190's Avatar
Re: ses and security
Help! Anyone.
I think I'll pull the ecm and look for blown or burn components, and maybe cracked solder joints.
Please anyone with an idea I'd love to hear it.
Old Jun 11, 2008 | 12:24 PM
Pop45398's Avatar
Car: '91 RS
Engine: 355 on a stand
Axle/Gears: 3:42
Have you tried removing and reseating your chip?
Old Jun 11, 2008 | 08:53 PM
vette9190's Avatar
Thanks for trhe reply
yes I have tried reseating my chip. and now to further enhance things i got the security light to go out but the ses light is still on when I short pins a b nothing is happening. my ses light just stays on it doesn't flash at all and now i'm getting a weird ticking from the dissy too. WTF?
Old Jun 11, 2008 | 09:02 PM
Pop45398's Avatar
Car: '91 RS
Axle/Gears: 3:42
When you first turn the key to the on position (without turning it to crank the engine) the SES light should turn on briefly then blink off then back on once. If not there is likely a problem with your computer.
Old Jun 12, 2008 | 04:44 PM
vette9190's Avatar
Could it be the memcal is bad?
Old Jun 12, 2008 | 08:10 PM
vette9190's Avatar
Well i replaced the ECM and still nothing. Any one know how I can test the memcal to see if its any good?
KNow any cars that have a memcal i could use I have a couple junkyards around I can try to source one. I don't have the kind of money I see being asked for these things so I'm kinda screwed here.
Old Jun 20, 2008 | 02:45 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Any chance you installed it backwards?
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
FormulasOnly
Jul 23, 2018 08:47 AM
FormulaEngland
Sep 30, 2015 01:50 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
