EXPERIENCED TPI GUYS NEED HELP PLEASE
I HAVE A 1991 Z28 5.7 L98 W/COMP CAMS ROLLER CAN, BORED .30 OVER,
30LB INJECTORS 58MM THROTTLE BODY ADJUSTABLE FPR, MSD IGNITION, PORTED MANIFOLD, PLENUM, LARGE TUBE POLISHED MATCHED RUNNERS.
I NEED TO BURN A CUSTOM PROM
THIS IS THE PRODUCT I WAS THINKING OF USING
http://www.moates.net/product_info.p...products_id=54
IM NOT SURE IF THIS KIT CONTAINS THE CORRECT CHIP TO BURN
PLEASE REPLY!
PLEASE REPLY!
Re: EXPERIENCED TPI GUYS NEED HELP PLEASE
http://www.compcams.com/Cam_Specs/Ca...?csid=186&sb=2
THANKS IS THAT SOMETHING YOU HAVE TO KNOW WHEN YOU BURN YOUR CHIP?
Car: Used to drive a camaro
Blue, absolutely. An aftermarket cam will obviously need different things than a stock cam. Your idle timing will usually be slightly higher, your VE (volumetric effiency) will almost certainly be different. Of course you could just slap in a stock tune and cross your fingers. That pair of crossed fingers will quickly turn into 1 middle finger sticking up once you discover all the things your engine is doing wrong with a stock tune and aftermarket parts...ie idle, take off, WOT, etc.
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
