Stock 87 5.7 TPI Bin
Old Feb 21, 2009 | 02:32 PM
jeeping68's Avatar
Car: 78 Jeep CJ7
Engine: 87 Chevy 383 TPI
Axle/Gears: 4.56
I am looking for a stock Bin file for an 87 5.7 TPI with 700R4 out of a camaro. I believe it is an ABYA bin. Can anyone verify that for me? I have looked at several sites, including Moates, diy-efi as well as eecis. Does anyone know where I can fine one? Also, I am looking for the $32B XDF file for TunerPro. Can anyone tell me where I can fine one?
Old Feb 26, 2009 | 10:12 PM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
Re: Stock 87 5.7 TPI Bin
You MIGHT get lucky here:
http://www.eecis.udel.edu/~davis/z28/index.html
Moates has the $32B definition, but its called a Binary Editor File under Tunerpro XDF Files.
The only documentation I could find for a stock BCC code for F body 5.7 L TPI are:
ABWN auto 3.27 gear federal emissions
ABWT auto 3.27 gear federal emissions
ABWW auto 2.73 gear federal emissions
Moates has an ABWT in the stock binaries section. If you burn it to a chip and scan it with tunerpro or Winaldl it should say 8201 under prom ID.
Old Mar 2, 2009 | 10:43 AM
jeeping68's Avatar
Car: 78 Jeep CJ7
Axle/Gears: 4.56
Lucid,
Thanks for the info. I got on Moates site and was able to find what I needed.
Another question comes to mind though. Does anyone know what the difference is between federal emissions and California emissions? I need to meet California requirements and I'm not sure how much difference there is between the two standards.
Old Mar 2, 2009 | 01:02 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
In general they run less timing a little richer for the Cali emissions. This lowers the HC & NOX levels. Needing to meet Cali emissions I would start with a Cali calibration. Then leave the speeds/loads where the emissions is checked alone.
RBob.
Old Mar 2, 2009 | 04:37 PM
jeeping68's Avatar
Car: 78 Jeep CJ7
Axle/Gears: 4.56
That raises two questions: What bin would I be looking for to be California Emissions compliant? And any idea where I can find one at?
Old Mar 2, 2009 | 08:26 PM
jeeping68's Avatar
Car: 78 Jeep CJ7
Axle/Gears: 4.56
I had another thought on this subject. Could I get a $6E mask for my smog test? If so, can I change the prom id to match what would show on an 87, or is that even necessary? Also, again, which California smog emissions bin would I use?
Old Mar 3, 2009 | 11:43 AM
Lucid's Avatar
This page shows a lot of the Prom BCC codes:
http://www.chevythunder.com/
I am not going to say ARAP wouldnt work in your project but there are a lot of things that you will need to change to make it work. Its for a stock aluminum headed engine.
The spark tables are really aggressive, the EGR is controlled differently, the startup fueling is less, and a whole bunch of other differences.
In your case, it maybe easier to find a California Emissions Fbody BIN.
Ebay, craigslist? Have you posted up in the california section to see if anyone has a Cali emissions Memcal?
Old Mar 3, 2009 | 01:30 PM
jeeping68's Avatar
Car: 78 Jeep CJ7
Axle/Gears: 4.56
Great idea on the Craig's List. I never even thought about that. I will take a look into that today.
I looked at the chevythunder site and they list a lot of California Emissions proms for the 305, but nothing for the 350. I think I will shoot them an email as well and see if they have any further insight that can help me out.
Thanks for the possible new leads Lucid.
Old Mar 5, 2009 | 05:35 PM
jeeping68's Avatar
Car: 78 Jeep CJ7
Axle/Gears: 4.56
After quite extensive research over the past couple of days, including speaking with a PROM burning company I have worked with in the past, I have been told there were no California Specific Emissions settings on the 1987 5.7 motor. The 5.0 had specific settings, but the 5.7 used the Federal Emissions settings. As a final check, is anyone aware of anything different?
Azrael91966669
25
Jun 20, 2017 04:04 AM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
