Do upgraded heads require a tune?
Old Mar 9, 2009 | 06:12 AM
SDalt404's Avatar
Car: 1988 GTA
Transmission: 5 Speed
I am going from stock heads to a set of trick flows. I am curious if this will REQUIRE a tune or if I can still run the car hard without one. Also will it affect drivability. My logic says that the air flow is metered by the mass air flow meter so it shouldn't make that big of a difference.
Old Mar 9, 2009 | 07:08 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Do upgraded heads require a tune?
Spark advance requirements will change. You'll be able to drive the car with what is in there now. But best results will be from you re-tuning it.
RBob.
Old Mar 9, 2009 | 07:42 AM
SDalt404's Avatar
Car: 1988 GTA
If you were to guess, what would you say the power gains from swapping heads is? 75hp?
Old Mar 9, 2009 | 11:54 AM
90c350's Avatar
35 to 40hp if tuned right!
Old Mar 9, 2009 | 01:16 PM
Ronny's Avatar
I read once that MAF is limited in the amount of air flow it can monitor. Once you see increased airflow/horsepower the MAF may have to go. Search.
Old Mar 11, 2009 | 05:59 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
With 19# injectors, it is unlikely to max the Maf. You would need to be bigger than 24# to even get close.
Old Mar 11, 2009 | 06:43 PM
SDalt404's Avatar
Car: 1988 GTA
What does injector size have to do with how much air maf can meter?
Old Mar 11, 2009 | 07:01 PM
tequilaboy's Avatar
Interestingly enough, with a 13:1 AFR, 19 lb injectors and the MAF will max almost simultaneously.
Old Mar 12, 2009 | 10:49 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Once the MAF reading is max'd fuel can continue to be added via the PE tables. This is a common method. Note that the injectors still need to be properly sized. As I am not saying that this will continue to add fuel once the injector DC is at or above 100%.
RBob.
Old Mar 12, 2009 | 06:05 PM
SDalt404's Avatar
Car: 1988 GTA
How much power can you make with 19lb injectors?
Old Mar 12, 2009 | 06:45 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
A data log will tell you alot about where you are on air flow and injector flow.
As to max HP with 19# injectors 300 FWHP by calculation @ 43.5 psi fp 100% duty cycle .5bsfc.
Maybe someone with a similar setup could give a dyno rating.
Old Mar 12, 2009 | 07:17 PM
SDalt404's Avatar
Car: 1988 GTA
Right now I use tunerpro RT for tuning and datalogging. What would you recommend for tuning? What would you recommend for datalogging?
Old Mar 13, 2009 | 08:03 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Those are fine for tuning and data logging, they are what I use.
What is your max Maf grams/sec and your max injector ms and at what rpm do they happen? They should repeat as you go up the gears.
Old Mar 13, 2009 | 09:15 AM
Ronny's Avatar
This is what I found for you. Save to your favorites.
http://www.users.bigpond.net.au/ben_...ctorsizing.xls
Old Mar 13, 2009 | 12:14 PM
SDalt404's Avatar
Car: 1988 GTA
thanks for that calculator. I will definitely be using that!
Old Mar 13, 2009 | 02:17 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Try this, it has been added to and "a work in progress", just remove the".txt".
File Type: txt
Old Mar 13, 2009 | 03:13 PM
SDalt404's Avatar
Car: 1988 GTA
Thanks big time!
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
86White_T/A305
Aug 17, 2015 12:16 AM
