Cruise Control Question
Old Jul 14, 2009 | 08:00 AM
dan0617's Avatar
Is there any way to tame down the cruise control? Now that the car is making good power and the tune is good, when using cruise control the car gives too much throttle to speed up a little and takes away too much throttle to slow down a little. Car is a ratchetfoot! Is there any way to tame down the amount of throttle the cruise control gives and takes?
Car is an '89 vette running 165 ECM with 6E ARAP based tune.
Old Jul 14, 2009 | 08:37 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Cruise Control Question
Cruise is controlled by a separate module. You will need to hac it and find out what part of the circuit controls the feedback loop. There is nothing in the ECM for this. Except to pull some timing to reduce the power and responsiveness of the engine.
RBob.
Old Jul 14, 2009 | 09:23 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I had that same problem once with a 2600 lb car and a large engine.
It would always overshoot the throttle adjustment, especially at slower speeds <65mph.
I had to re-engineer the cable connection to the throttle lever.
I had to add some slop in the connection, and limit the total throttle movement added by the cable. It fixed the problem enough to eliminate the surging at highway speed.
Some cruise control controllers have a DIP switch that can change the gain of the system. I don't know about factory GM units though.
In some cases it may be possible to swap the vacuum diaphram that controls the cable to something smaller with less power and less travel.
Old Jul 14, 2009 | 01:22 PM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
Or modulate the vac source maybe? Some sort of solenoid to prevent vacuum buildup in the diaphram and only send vac to it when the system is on, doesn't seem that hard to rig up with a 12v vacuum solenoid pocketed at the JY, some wiring diagrams and some beer.
Old Jul 15, 2009 | 07:26 AM
dan0617's Avatar
Mine does have a vac diaphragm controlling the cable, I'll have a good look at it tonight and see if I can adjust the cable somehow, or add a little slop to it. Never thought of that. Probably wouldn't take much.
Old Jul 15, 2009 | 10:32 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Actually, having too much slop in the cable will cause exactly what you are describing.
HTH
Old Jul 16, 2009 | 10:35 AM
Ronny's Avatar
I have same problem but again only <60 mph. tI think the issue is agrivated by my 7.4 TBI unit. Sequential throttle linkage might be the ans.
Old Jul 16, 2009 | 12:35 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
If you're good at welding you could extend the length of the throttle lever where the cruise cable attaches. Then, same movement of cable = less throttle opening.
Old May 4, 2012 | 06:18 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
RBob.
I'm having the same problem with my GTA now too. Makes tons of low end and the cruise is too aggressive. RBob, has anyone done what you describe before?
I've also thought of purposely adding a vacuum leak at the vacuum servo to tame it down a bit.
Old May 4, 2012 | 07:27 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Not that I know of.
I think that the idea 305sbc has with extending the lever arm has merit. It will also reduce the maximum amount of throttle the CC will provide, but all-in-all, that isn't a bad thing. As it won't be needed.
And extending the throttle arm (lever arm) will reduce the amount of correction.
RBob.
Old May 4, 2012 | 11:08 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I have the same problem with a few cars, one is modded to beat the band and on is stock with gears. Well both have 3.73 gears (with proper speedo gears) and both cars surge badly at highway speeds with the cruise control on.
Maybe GM techs would have the answer???
Old May 4, 2012 | 11:55 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
When I went from a 160 HP 305 with a Q-Jet to a 454 TBI and later a TPI setup I had the same issue in my van. Just a little hill would overshoot 5-10 mph! Cruising along at 75 you were suddenly at 85 mph going up hills. What I did was move the pivot point on the throttle body further away from the centerline. Now instead of being able to give full throttle or close to it, the cruise control can only give a little more than 1/2 throttle. With close to 500 ft/lbs of torque on tap, compared to my stock 235, its not a problem. Even half throttle is enough to downshift to 3rd and move it right on up the hill or past the car. Pretty funny when people that won't let you around them, see you push the button on the cruise stalk and burn past them.
Old May 4, 2012 | 11:59 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Not that I know of.
RBob.
This is what I did too....My van actually is a mix of GM cruise control parts. I think the brain was from a 92 G20 and the module an 87 2.8 S10, controlling a TPI throttle body with a revised cruise control linkage mounting point.
Old May 5, 2012 | 08:16 AM
TTOP350's Avatar
That makes sense. I was thinking about upgrading to the newer "eletronic box" type and going from there buuuuut this gives me a idea to work with.
How far out did you move the piviot ? I have atleast doubled the power an then some with my setup..
Old May 5, 2012 | 08:45 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
I looked at my TB last night and it does look like lengthening the lever will be the easiest route. I was going to add about 3/16" or so. With over 500ftlbs and a T56 I certainly don't need much more than 1/2 throttle actuation either, even in a chubby GTA.
Old May 5, 2012 | 09:48 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I think I moved mine 3/8" up from the centerline and slightly rear-ward. Too much and you will get the cable binding on you.
Even towing a trailer behind my un-aerodynamic G-van, I never need more than 1/2 throttle to maintain speed. I can do 70 mph, pulling 5,000 lbs on a dual axle trailer up a 6-8% grade with no more than 1/2 throttle. Pretty amazing what torque will do.
Old May 5, 2012 | 10:05 AM
morgsie's Avatar
Is there not multiple attachment holes for the cable @ servo? Would this not help?
Old May 5, 2012 | 12:44 PM
TTOP350's Avatar
I don't think so. thats for a different type of adjustment. (cable length?)
Old May 5, 2012 | 01:16 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
I just extended my throttle bracket straight down 3/4" and you'd never know it wasnt stock that way. I haven't driven the car to try it yet but will later today.
You say you moved the bracket up? Must be talking about a TBI throttle body? I just want to be clear on that so folks don't get confused.
Old May 6, 2012 | 11:25 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Yea that was on a TBI throttle body. On a TPI throttle body it would be down. The throttle linkage needs to move OUT or AWAY from the centerline so that the same pull give less rotation of the throttle plate. Thats the easiest way to say it to confuse less people.
Old May 8, 2012 | 12:04 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
OK so my trick of adding .750" to the arm on my throttle linkage where the cruise servo attches seems to have worked very well. Smooth engagement and steady speed up and down hills and all. Keeps the big stroker nice and tame....
Old May 8, 2012 | 02:44 PM
TTOP350's Avatar
Very cool. I guess I'll give it a go then!
eightsixseven
Dec 16, 2024 01:50 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Street Lethal
Aug 12, 2015 11:33 AM
Bull86
Aug 10, 2015 05:43 PM
