once again another newbie wanting to tune
Old Feb 1, 2010 | 06:03 PM
rokcrawlin85's Avatar
Car: 85 chevy k5
Engine: TBI 350 H.O.
Axle/Gears: 4.10
so i've been reading a ton of articles off this site!! just a fantastic site for us to learn off of. thank you all for great posts.
i've got a few questions still...well alot but ill learn in time im sure. im running the 8747 ecm. a fullsize chevy truck yes. i've been dealing with affordable fuel injection (anyone know that company?) for nearly 2 years trying to get a good tuned chip with no luck yet. so i decided to try my own luck. i haven't bought any hardware to burn yet. just want to get my mind in the right place first.
im sure ill leave some info out that you may need to help me so just get back to me and ill let you know about it.
a few questions i have are: i have tunerpro rt now, should i use my bin i pull off of the chip i have as a base to go off? or what bin off moates to use? also what definition file to use?
i understand about changing ve tables and timing tables (obviously will be a deeper subject once i really start getting into it for myself). thought i was understanding everything pretty well until i came across talk of locations inside the bin like the talk of "location 0x0ff" or things like that? what posts can i look at to understand this? i've searched but it just leads me to posts that talk about it like i should understand it. im totally lost with this lingo. i know its hex but how does that work with finding stuff in the bin? do i need to know these things?
also people talk about the flash and burn at moates but i've found the burn 2. what does everyone think about that burner?
and anything else that anyone has a thought on about a newbie getting started please speak up.
Old Feb 1, 2010 | 07:00 PM
J_D_'s Avatar
Re: once again another newbie wanting to tune
You dont really need to understand hex. Tunerpro RT takes care of that. You can pick it up if you want. Flash & Burn is the software you need to make the Burn 2 work. I'm a noob myself but 5 minutes after receiving the Burn 2 I had burned my first chip. Great tools to have. I cant help on the specifics of your tune though, I have an entirely different vehicle.
Old Feb 1, 2010 | 07:15 PM
Car: 85 chevy k5
Axle/Gears: 4.10
awesome any help along the way would be great! ill be needing help, im sure along the way. so then ill just need to buy the burn 2 hardware then and then flash and burn is just the software with it?
what is needed for me to be able to use a eeprom with my ecm? what chip will i need? i got a little confused with following that post...
so without tunerpro, hex is the only way to read a bin? with the math that is
Old Feb 1, 2010 | 10:48 PM
Car: 85 chevy k5
Axle/Gears: 4.10
fyi, its a 85 chevy k5 blazer. im running the gm crate 350 h.o. motor. heated o2, a 350 tb out of a 91 suburban 3/4 ton (thus the hd setup ecm 8747) no knock sensor or vss. if i knew what i know now (after reading on this site) i would of had the harness made with a knock sensor but at the time i figured less sensors to go wrong the better. i hope that doesn't hurt me too bad in the long run.
i know that this is a small tb for my motor but im into the whole rock crawling scene so i just need low end power not really the go go go power of most of you guys out there. im usually real easy and low in the rpm band so im hoping to be able to tune this tb for just some everyday driving and wheelin. can it be done?
Old Feb 1, 2010 | 11:33 PM
whitelightnin92's Avatar
you may be better off getting the ebl...
Old Feb 2, 2010 | 05:25 PM
Car: 85 chevy k5
Axle/Gears: 4.10
ebl? sorry please explain
Old Feb 2, 2010 | 08:20 PM
dynamic efi makes the ebl, its a plug-n-play ecm. you tune it and datalog through the same cable and comes with bins to start with. Rbob here on thirdgen makes it.. i wish i had it instead of the 7427
Old Feb 2, 2010 | 09:04 PM
Car: 85 chevy k5
Axle/Gears: 4.10
ya that sounds real nice! just one problem. on a super tight budget with to little ones in the house now.
i'd really like to just get this running decent enough as is with what i have. probably upgrade to bbc injectors later but for now i really need to try and stick with what i have. not the best option i know but i think its what im gonna have to do
Old Feb 2, 2010 | 10:07 PM
well do you have any tuning equipment yet? by the time you get everything you need you are almost to the point you could buy the ebl.
is it a stock TBI350 or what? mods?
Old Feb 3, 2010 | 05:10 PM
Car: 85 chevy k5
Axle/Gears: 4.10
thats a good point. i fugure i can buy a burner, the adapter for my ecm to be able to use the eeproms, along with a couple chips for less than $300. is the edl less than that? what else is needed with the edl to tune?
as far as i know there are no mods to this tbi. just a stock 3/4 ton 350 suburban tb. the guy that was trying to tune a chip for me (from affordable fuel injection) believed that they were cop car injectors. i doubt they are
Old Feb 3, 2010 | 05:18 PM
the ebl only needs a laptop. it comes with everything you need. i think its $450 for the complete ecm. but if your soldering skills are good then you can buy the circuit board and install it in your ecm to save some cash.
check it out
http://www.dynamicefi.com/
Old Feb 3, 2010 | 05:19 PM
http://www.dynamicefi.com/EBL_Purchase.php
price isnt bad if you consider it comes with EVERYTHING
Old Feb 4, 2010 | 09:24 AM
Car: 85 chevy k5
Axle/Gears: 4.10
ok i went and checked it out. looks like a nice product to have installed. now im gonna need to decide between the two options.
lightnin, i have you opinion, thank you for that
anyone else have input on which way to go? anyone have a preferance from what they've used?
Old Feb 4, 2010 | 02:41 PM
Ronny's Avatar
8747 definition file 1228747-160baud ver1_01.ads
binary akwa(one ton van)
see Craig Moates downloads
Old Feb 4, 2010 | 08:40 PM
yeah if its stock then why not put a stock chip in it?
Old Feb 5, 2010 | 07:35 PM
Car: 85 chevy k5
Axle/Gears: 4.10
ya i need something, im sure, with a more aggressive timing table at least. i haven't picked any tuning hardware yet, now im stuck deciding which way to go (ebl or burn 2) either way ill be able to see what bin AFI has me running now and change it from that point im hoping
Old Feb 6, 2010 | 11:02 AM
wyochimneysweep's Avatar
Car: 92 chevy 1/2 4 wheel drive
Engine: 5.0L with TPI
not only will you need a burner for chips but do you have a have to datalog to be able to see your changes? If not you may want the dynefi. it allows datalogging and programing all in one price
Old Feb 6, 2010 | 01:15 PM
Car: 85 chevy k5
Axle/Gears: 4.10
i got the datalog thing down. i use winaldl to take a look at my blm's and what not
Old Feb 7, 2010 | 10:04 AM
Car: 85 chevy k5
Axle/Gears: 4.10
ok i think im gonna go with the burn 2 and the g2 adapter with a couple flash chips. ill be spending less money than for the ebl. seems like the ebl would make tuning alot easier and faster, but i have to go with the cheaper one.
anyone using the 8747 ecm with this setup? which flash chips do i need to get?
Old Sep 19, 2011 | 01:53 PM
y5mgisi's Avatar
Car: 90 Chev Suburban 4x4, 5.3L, th400
Engine: 2002 5.3 Vortec swapped in.
Transmission: Stock th400
Axle/Gears: 10blt front/ 14bltSF rear 3.73 gears.
Hey Ronny, any more info about this? I cant seem to find where to download that bin and ads. Is it on the moates site somewhere?
Old Sep 19, 2011 | 02:36 PM
Ronny's Avatar
Craig Moates under downloads. look far left on home page near the bottom.
Old Sep 19, 2011 | 07:22 PM
y5mgisi's Avatar
Found it
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
nuggie
Aug 25, 2015 01:27 PM
R3500
Aug 24, 2015 09:05 AM
