VATS disable in chip?
Old Jul 23, 2010 | 05:52 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
I had my VATS begin acting up today leaving me stranded for about 20 minutes. Finally the car would turn over and I got home but its very annoying and I already had the dealer fix the VATS issue about 12 years ago. I know I can measure the ohms in my key and wire in the correct resistor. I have also heard you can connect two of the wires and get it to run. The car is now parked until I figure this one out. My question is can I simply disable VATS by burning a new chip? From what I understood that is one of the ways to disable it without soldering the resistor. I already have an ALDL cable and wanted to get an EPROM burner, eraser & chips anyway. I'm thinking now would be the time to invest in the burner / reader and a few chips. Can anyone tell me if I can simply turn off VATS by setting some flag and burning a new chip? If so, I will purchase what I need next week.
Thanks for any input.
Old Jul 23, 2010 | 06:44 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: VATS disable in chip?
Yes, it is possible.
Old Jul 23, 2010 | 06:49 PM
uraijit's Avatar
Possible, and very easy to do. It's just a flag change.
Old Jul 24, 2010 | 08:44 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
My TA did this at a friends house one time. He took me home to get my tuning equipment. I burned a new chip for the car in 5 minutes it started up and was fine.
Old Jul 24, 2010 | 09:53 AM
MY-92-RS's Avatar
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
For Tune Port Injected Car YES very easy .. for TBI not so much
I have ripped all the computer injection system out of my 92 rs it is now has a carburetor -- vats is a separate box and still can disable the starter using the start enable relay
Old Jul 24, 2010 | 11:51 AM
Easy fix that a simple jumper wire would take care of.
Old Jul 24, 2010 | 02:04 PM
MY-92-RS's Avatar
Exactly -- tbi jumper wire on start enable relay TPI program chip and turn it off
CG
Old Jul 24, 2010 | 02:13 PM
MY-92-RS's Avatar
CG
Old Jul 26, 2010 | 11:41 AM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Ok, so what should I do? I've read about cutting two wires and wiring them together. A yellow one from the column and a tan & white one from the shifter. I hear this will bypass VATS, but why different from TPI car? I have a TBI car. Can I disable in chip as well? Should I do the wire thing? I'm looking for better information on which wires to cut. I'd like to drive my car!!
Old Jul 26, 2010 | 12:03 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes you can disable the fuel cut in the chip. Although if you can read the resistor in the key and wire it in, could probably do that in 5 - 10 minutes be be driving.
VATs systems are the same between the TBI, TPI, and MPFI cars.
RBob.
Old Jul 26, 2010 | 12:51 PM
uraijit's Avatar
Just do it in the chip. Uncheck the VATS switch/flag, and burn the chip. Should take care of it. No need to cut wires.
If you decide to the the wire cutting route, there should be an orange wire in there, that actually has two wires inside it. Measure the resistance on your key, and then wire the resistor across those two wires.
Old Jul 26, 2010 | 01:09 PM
Stephen's Avatar
Car: 87 GTA
Why cut wires? Just unplug & insert the correct resistor.
Resistor Chart:
Old Jul 26, 2010 | 01:56 PM
uraijit's Avatar
Because just jamming it in there isn't very secure/reliable. Solder is the only electrical connection I trust not to strand me...
Nevertheless, why even bother with the resistor, when you can more easily disable it in the chip?
Old Jul 26, 2010 | 02:04 PM
Stephen's Avatar
Car: 87 GTA
Because, and it is already said above.....
You can't do that for TBI, which the OP has. A PROM change isn't even an option for him.
Old Jul 26, 2010 | 02:28 PM
uraijit's Avatar
False.
Yeah, it's been said, but that doesn't make it correct.
Old Jul 26, 2010 | 02:33 PM
Stephen's Avatar
Car: 87 GTA
Originally Posted by uraijit
False.
Believe that if you want, but the VATS Module disables the starter in any case, so a PROM change won't help. PROMs have no affect on the starter circuit.
And the resistor is a 15 cent fix. How cheap is a reprogrammed chip.....
Old Jul 26, 2010 | 05:14 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Well I measured the OHMs at 887. Radioshack didn't have the correct resistor. I ended up buying a $0.25 910ohm resistor from a local electronics store. I'm going to pop that in next to make it work for now. I also read with my ALDL cable and WinALDL and it showed the error code 53 VATS error. Car started fine then too but I just didn't want to get stuck somewhere again. The resistor it will be for now since I don't have the eprom programmer and chips yet. I plan to also begin burning chips soon and to remove it there as well. I'd need to order one which would take a few days.
Thanks for all your help guys.
Old Jul 26, 2010 | 06:30 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
I tried putting the resistor in just like the picture Stephen provided and it doesn't do anything. The resistor seems to fail as well. Any other ideas?
I had it start once without the resistor. I then unplugged the plug with the orange wire and it didn't start. Plugged it back in, car started. Then, I tried to jump it with the resistor and I began getting the SECURITY light again and no start, no crank. Now with or without the resistor plugged in I get the SECURITY light. It is an intermittent VATS issue, so I wanted to make sure the resistor is working. I also assume to leave the plug plugged in when putting the resistor in correct?
Old Jul 26, 2010 | 06:33 PM
Stephen's Avatar
Car: 87 GTA
It is sounding more like a bad VATS module. If that is the case....Good key or not, it could start/not start.....off & on.
Old Jul 26, 2010 | 06:34 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
CG
So, how would I go about doing this start enable relay thing and finding the correct wires?
Old Jul 26, 2010 | 06:38 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
I tried this and it the car doesn't even show the security light when I turn the key over. I unplugged that plug with the orange wire that has the two wires inside it. Stuck the resistor into the plug and nothing.
Old Jul 26, 2010 | 06:48 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
I'm also beginning to think the relay may be going bad as well. I read another similar thread where that was mentioned. What got me really thinking that was I had two codes. VATS(53) & Fuel pump relay(54). I've already replaced my fuel pump before, relay, etc not long ago with a Walbro. I know I have fuel and it just wont turn over at all when it does this. Does anyone know if the Fuel Pump Relay is the same Relay? I'm about to replace that next or swap it with another relay when it wont start.
Also, if it is the VATS module in the column would that cut wires and connect the right ones together be a workaround?
Old Jul 26, 2010 | 08:17 PM
You want the connector for VATS from the column disconnected when doing the resistor bypass. When you leave it connected the resistance is actually less, due to having two resistors in parallel, one being the resistor you are adding, the other being the original resistor in the key.
Old Dec 21, 2010 | 10:40 AM
toneye's Avatar
to any member willing to help i have a 91 camaro rs 5spd havings VATS problems again want to bypass for good ive read about resistor fix and chip for ECM and VATS bypass module not sure what to do or use one of the three methods ive read about can anyone help me so i can start car and get rid of VATS for good thank you to any any everyone willing to help me thank you members
Old Dec 21, 2010 | 10:52 AM
Stephen's Avatar
Car: 87 GTA
If your VATS module is good, the resistor bypass is the cheapest, easiest & anybody can do that.
Old Dec 21, 2010 | 11:40 AM
toneye's Avatar
from toneye i just read a message from stephen about 91 camaro vats problem hope i reached the right guy i read about bypass on message board from 7-26-10 hope this is your post i can go by your pictures of wires to fix my problem thank you for helping with information you info is greatly appreciated glad you helped and posted pictures
Old Dec 21, 2010 | 10:35 PM
toneye's Avatar
hey1meanz i have a 1991 camarors 305tbi 5spd i read your post can a chip be used to disable the vats for good other post say you can not use prom for my ecm but you burned a chip for your car did this get rid of vats for good i would like to do same thing so i can drive car again can you help with vats headache this is not the first time for vats problem
Old Jul 18, 2012 | 08:47 AM
rocn7roc's Avatar
Can anyone tell me exactly how to disable the vats in the prom. thanks Mike
Old Jul 18, 2012 | 10:20 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It is a flag that gets un-checked. Most of the ECU & XDF files have that one defined. Will need to know which MaskID you are using to provide more information.
RBob.
Old Jul 18, 2012 | 11:32 PM
Steve31's Avatar
Ok after you buy the hardware / software needed open the bin with tunerpro
double click on the little red flag and it will like the image below.
This forum has 1 of the best threads I have seen for as DIY tuning
I am sure you can find full details ,step by step almost in here
https://www.thirdgen.org/forums/diy-...uide-book.html
Old Jul 19, 2012 | 03:51 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Years ago I had the same problem, I work for small electronic R&D company so did the resistor trick. I measured the key got a couple of resistor in parallel to match exactly, I unplugged the connector to the ignition switch and connected the resistors to the VAT side but I think made a new connector and just plugged it in. I don't remember cutting wires, I've since had a prom burned removing the VATS altogether.
Old Jul 19, 2012 | 04:32 AM
MaxpowerTA's Avatar
Car: 1992 T/A convertible
Engine: LB9 TFS175heads Ebase/accel runners
Transmission: T5 5spd
Axle/Gears: 4.11
Keep in mind disabling VATS in the prom will only disable the fuel cut, It will not get rid of the starter interlock, So if you are having a problem where the car intermittently wont turn over changing the prom will not fix that.
Old Jul 22, 2012 | 09:36 AM
rocn7roc's Avatar
How can I do this myself,any instructions out there? Thanks Mike
Old Jul 22, 2012 | 12:00 PM
utilityguy2's Avatar
Several people have answered your question. There are numerous stickies at the top of the board that provide instructions. Set back and start reading them and get a sense of what you are asking. Then get the hardware and software to do it.
Old Jul 24, 2012 | 07:22 PM
toneye's Avatar
i bought my VATS disabler from GATOR tools hooks in to exsisting orange and white wire i then hooked my battery cables together to drain battery and ECM charged battery and car started. part cost about fifty bucks part was from Oregon
Old Jul 24, 2012 | 09:25 PM
What??? battery cables together? ECM charged battery?
$50 is too much for a 5 cent resistor.
But if you're happy that's all that matters. I guess.
Old Jul 29, 2012 | 08:53 PM
toneye's Avatar
no i dont think the price was too much my car is up and running no more VATS problem.remember you have to know what key you have and get the right resistor or risistors and solder them together.******* rickem has video on you tube showing resistor fix. i used GASTOR TOOL part fifty bucks is a small price to pay for getting my car back and driving it
Old Jul 29, 2012 | 09:44 PM
toneye's Avatar
i hope you get a chance to read my reply i used GATOR TOOLS bypass simple plug it in to the orange and white plug set switch to your key number. i then hooked my battery cables together to drain ECM.charged battery up and car started.price was fifty dollars.since my car is TBI vendors dont have a chip to bypass.they do have a bypass for TPI models
ive talked to vendor.so i went with gator tools part been driving since.you can see from my past post my problem is gone now.so good luck i didnt have much luck with the resistor fix.but GATOR helped DRIVING car again
i hope you find the right fix so you can enjoy your car again.or you can buy factory repair manual i did they show info about VATS
Old Jul 30, 2012 | 12:31 PM
He is asking how to do it in the prom, not how to wire in a bypass. This is the Prom board and he has been answered how to do it in the prom.
Old Jul 30, 2012 | 04:56 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Only problem is the resistor trick only works if the problem is on the key side of the vats system. Sounds like a bad vats module
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
jaridjohn
Oct 5, 2015 07:01 AM
