Prom/chip for 730 swap??
Car: 1987 IROC-Z
Engine: L-98 350 TPI
I am swapping my 165ecm to the 730 ecm. What prom/chip will work?
Part number would be helpful.
Also looking to buy a Common 24/32 ECM Header connector. Thanks Shane
Transmission: 5-speed/T-5
Re: Prom/chip for 730 swap??
I would assume that the reason you are doing this swap is to go from MAF to MAP, correct?
AUJP, would be good, or you could use S_AUJP, if you want WBO2 logging, and extended VE tables.
I don't understand what you are meaning by a common header.
Car: 1987 IROC-Z
I am doing it because the 730 is able to tune as you drive and you dont have to take out the prom out to burn it.
What prom would be the best?
The 24-32 pin connector..its what the harness plugs in to the ecm
I still don't understand what you mean by, "The 24-32 pin connector..its what the harness plugs in to the ecm."
What harness?
Car: 1987 IROC-Z
I am talking about this right up... http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
To tune the 165 ecm you have to take out the chip Right?? and the 730 you don't?? My tuner recommend that i up grade my Ecm, something that is easier to tune,faster and a better ecm for future mods such as Super Charger...
Car: check
Engine: check
Transmission: check
RBob.
*sigh*
Both use the same basic ideas as far as programming.
Both need to have the EPROM removed or use an adaptor.
Both ECMs will work, both the '165 and '7730 have been used in many different applications. I'm running a '7749, which is very similar to the '7730 in my Datsun running the Nissan engine. I have for a short period used a '7730 temporarily in place of the '7749 during some testing.
Dynamic EFI makes a daughter board for the '7747 and similar ECMs that upgrades that ECM for better datalogging, and more input and output options.
Car: 1987 IROC-Z
What would you recomind? I am looking for a a Ecm that doesnt require taking out the prom to burn or make changes. I want somthing that i dont have to change for furture mod such as a supercharger.. Thank for the help!!!!
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
See the link in RBob's reply.
There is nothing else that is as fully featured or easy to use for your needs.
Hello, Michael
Aug 20, 2015 03:19 PM
