Getting started with Tunerpro R/t
Old May 14, 2011 | 09:17 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Ok, a little confused here. I have a copy of Tunerpro r/t. I have an 8D.xdf file, an AUJP 8D.bin , a 1227730 8D.ads, a Super8Dm2.ecu file, a 1227730 8D.adx file. Which ones am supposed to be loading? and where? I think i am asking , am i supposed to use the ads file and the ecu file which i found on the tunerpro site? or use the AUJP bin file and the 1227730 adx file?
Old May 15, 2011 | 09:02 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Getting started with Tunerpro R/t
Here's how this works.
TunerPro V4
*.ecu file = Bin Editor definition
*.ads file = Datalogging definition
TunerPro V5
*.XDF file = Bin Editor definition
*.ADX file = Datalogging definition
*.Bin files are the "working" file for your engine controller (ECM)
This is a 1227730 ECM in your case.
The ECM uses a configuration of inputs/outputs as defined by the "Mask ID" of $8D
Any $8D software will "operate" without changing wires in your car (for the most part anyway)
Your bin file "AUJP" contains the variable settings you will edit to tune the engine.
The $8D definition (or other mask ID) has a defined datastream output from the ECM.
Using the *.ads or *.adx file, it translates or converts the hex characters to engineering units that you can understand.
So load bin editor definition.
Load a logging definition
Load up the bin to edit.
Make edits, save to chip, try it out.
Tweak the tune until finished
The V4 files can be "imported" to V5 but V5 files do not work in V4.
Old May 15, 2011 | 02:10 PM
ninetyone's Avatar
Axle/Gears: 3:42
I have the $8D .bin file and the $8D.xdf file and loaded both and could not hook up. I am using Tunerpro 5 rt. Now i do have a 1227730 8D.xdf too. Need some more advice here.
Old May 15, 2011 | 02:11 PM
ninetyone's Avatar
Axle/Gears: 3:42
Is the .adx the same as the bin file?
Old May 15, 2011 | 02:45 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
No.
The .ADX is used for datalogging. It is used to interpret the datastream.
The .BIN file is what the ECM uses to run the engine.
Old May 15, 2011 | 03:06 PM
ninetyone's Avatar
Axle/Gears: 3:42
Is it possible to do any damage by me loading the bin file?
Old May 15, 2011 | 03:09 PM
ninetyone's Avatar
Axle/Gears: 3:42
yeah, like i said, i loaded the xdf and then loaded the .bin file. LOL Instead of loading the adx and xdf.
Loading the bin to Tuner Pro? No.
Old May 15, 2011 | 03:12 PM
ninetyone's Avatar
Axle/Gears: 3:42
Well, i should say, could i have damaged my ecm by loading the .bin file into Tunerpro 5 and then trying to connect?
Old May 15, 2011 | 03:13 PM
Again, no.
Old May 15, 2011 | 03:14 PM
ninetyone's Avatar
Axle/Gears: 3:42
So basicaly i am turning on Tunerpro, then loading the *.XDF file = Bin Editor definition
*.ADX file = Datalogging definition right? then, create a log file? then press start data scan?
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
89fast5oh
Sep 27, 2015 09:04 PM
beast94
Aug 20, 2015 06:44 AM
tmellott89
Aug 16, 2015 02:58 PM
