i dont know how to or where to start
Old Nov 9, 2011 | 11:02 AM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Im new to this and im cutting cost again so i can get a used procharger. how do u burn a chip dumb it down too. whats the best whats needed whats the cost having some else do it for 500 a wast or should i do it myself.
mods
1pc main eagal 383
RHS almn head 220 cc runners 64 chambers
custom cam hyd roller
TPIS miniram
30# injectors
52 or 58 bbk tb
long tube headers
700r4 trans
4th gen rear 3.42
anything else i should add. lookin to make 500fwhp 475tq 620 with procharger 595tq
Old Nov 9, 2011 | 11:06 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: i dont know how to or where to start
Do it yourself, You don't state what ecm you are running !
Old Nov 9, 2011 | 11:15 AM
Sojer's Avatar
stock 87 ECU LB9 305 TPI
Old Nov 9, 2011 | 11:19 AM
Engine: Lb9
Transmission: M20
1227165, there is a osrtich1 for sale in the classifieds that would help you get started.
if you convert to sd check out www.dynamicefi.com the ebl p4
Old Nov 9, 2011 | 12:00 PM
Sojer's Avatar
i dont know what those # mean
Old Nov 9, 2011 | 12:05 PM
Engine: Lb9
Transmission: M20
you currently have a 1227165 maf ecm
Old Nov 10, 2011 | 10:30 AM
Sojer's Avatar
Ok how hard is it is it for dumbies I don't kno what fuel air ratio it should have someone should make a sticky on that's fuel air ratio to cubes and HP. How much does the whole thing cost.
Old Nov 10, 2011 | 10:41 AM
Engine: Lb9
Transmission: M20
stoichiometric is 14.7 you can safely go richer but to a extent with a stock singe wire o2 sensor. goto moates.net the cost will depend on what you want to do just burn , burn and datalog . emulate and burn later. Getting used tools will save you some cash..
Old Nov 10, 2011 | 11:06 AM
Ronny's Avatar
read stickies above.
Old Nov 10, 2011 | 04:34 PM
Sojer's Avatar
So I will need to run o2 sensors and what tools I have a soldering iron
Old Nov 10, 2011 | 04:39 PM
Ronny's Avatar
At highway cruise i am at 16/1. >40mph cruise 14.0/1 PE I am 12.5/1 AE approx 10.0-11.0/1 N20 about 12.0/1
E10 is 14.3/1 reg gas is 14.7/1 some run E85 and I recall it is like 9.5/1
you need to study the stickies above and read the thread "free tune" in TBI.
Old Nov 10, 2011 | 04:54 PM
Engine: Lb9
Transmission: M20
yeh, um.. maybe you should take it to someone
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
