Spark Retard at lower coolant temps
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
I have searched and have not been able to find what I am experiencing. When I first start my car and begin to drive with coolant temps around 30-50C, I get a lot of spark retard. Once the car reaches 70-80C all spark retard disappears. Full throttle, part throttle, idle.
Is there a table that adds spark to a cold motor to help warm it up quicker? If I am not mistaken there is one in $6E, as I had the same issue and was able to zero it out.
I am currently using $8D. Thanks
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Spark Retard at lower coolant temps
Code:
;======================================= ; ; COOL SA TBL, 12 BLKS ; $8138 - $81A7 ; ; TBL = (VAL + L8137) * (256/90) ;=======================================
Car: 86 IROC
Axle/Gears: BW 3.27
Thanks! Do you have the hack for $8D? What is the value at 8137?
Car: 86 IROC
Axle/Gears: BW 3.27
I was not able to find the hac? Do you know what directory it is within?
Car: 86 IROC
Axle/Gears: BW 3.27
At what point in the routine does it stop using that table to add spark? Once the ecm enters closed loop? Time delay?
Car: check
Engine: check
Transmission: check
http://www.diy-efi.org/gmecm/papers/anht_hac.pdf
It is on this page:
RBob.
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Why not refer him to an updated hac?
There are known problems that have been updated.
http://www.gearhead-efi.com/gearhead...20and%20Hacks/
Look for AUJP_JP2.zip
Car: check
Engine: check
Transmission: check
Yes, there are some errors in the original hac's, but they are better then nothing. I actually told that to someone that didn't like the ambiguities in my $61 hac. Flat out stated that if you don't like it, then do your own hac...
RBob.
Car: 86 IROC
Axle/Gears: BW 3.27
Looking at the hac, I cannot seem to understand how idle spark is calculated. My car will idle at 700-750rpm at op. temp, but in my logs the SA jumps all over the place. Looking at the tables none of the values make any sense. Can you run me through how idle spark advance is calc?
Car: 1985 IROC-Z28
Engine: LB9
possibly relevant, but assuming you remove the coolant temp dependant SA and still see KR, i've been in a few situations where even a slight misfire was being detected as knock. what would cause that at lower coolant temps and goes away at higher temps, i couldn't say, but just something to keep in mind.
For anyone to spend the time it takes to even get close to detailing code, there are always be ommissions due to time or errors that "hopefully" the next guy will help adding detail to.
And for those that complain after they spent two hours looking over something you've worked on for a year and find an error...
I'm glad to see there are still some people who have taken the time to go over existing works and make them better.
Thanks to those who try and share.
Jp
Car: check
Engine: check
Transmission: check
Thanks.
IIRC, $8D has a closed throttle SA table. So that will be used, then compensated for the idle RPM. Too high and the SA is decreased, too low and the SA is increased. Basically using torque control to smooth and prevent a rolling idle speed.
RBob.
Car: check
Engine: check
Transmission: check
Yup,
Jp
Jp
RBob.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 86 IROC
Axle/Gears: BW 3.27
I lowered the value at L$031 from 40C to 20C and that helped.
I played around with the idle SA adv and retard last night by lowering the values in the first few cells. At idle the rpm would hunt a bit, but the biggest difference that I noticed was that when in gear and slowly accelerated the car did not jump forward. Prior to changing those values the car would feel sluggish and then jump forward.
Fast355 - Do you recall where that constant is or what it is called?
morrow
Jan 13, 2024 12:29 PM
hydrolic144
Oct 4, 2015 08:23 PM
Night rider327
Sep 2, 2015 04:17 AM
