Ostrich Help
Old Jul 9, 2014 | 12:01 PM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Ostrich Help
Just purchased an Ostrich and need some help trying to get it to work.
Steps I am doing. Plug it into my laptop, fire up tunerpro rt, load my xdf and bin in tunerpro, make sure the Ostrich is present and working, upload my tune to the Ostrich and verify it. Using bank 0 as per docs on moates.net. Go to the car and it goes into limp mode. Put the chip in with the exact same tune and it works fine.
I then plugged the Ostrich into my chip burner and did a read, works fine. Next I loaded my tune into the burning program and did a verify, it fails.
What would cause the Ostrich to upload a bin properly AND verify within tunerpro, but the output from the Ostrich to fail? Am I doing the steps properly?
Old Jul 10, 2014 | 09:08 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Ostrich Help
Be sure to set the switches for the correct PROM size to be emulated.
RBob.
Old Jul 10, 2014 | 10:00 AM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Re: Ostrich Help
Switches are set proper for a 28 pin PROM.
Did another test last night. I loaded bin 1 into the Ostrich and pulled the output then saved it. Next I loaded bin 2 into the Ostrich and pulled the output and saved it. I compared both outputs and they are identical even though the original changed.
Old Jul 20, 2014 | 12:15 PM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Re: Ostrich Help
I finally got the Ostrich to work.
Now a new issue is coming up. Whenever I disconnect my laptop from the Ostrich, it goes into limp mode. I have confirmed that tunerpro is not emulating when I disconnect and I release the hardware in tunerpro.
Do I have to set the mask to AA even if I upload a bin to the Ostrich without emulating it?(thought that was for emulation only.
Old Jul 20, 2014 | 04:49 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Ostrich Help
What ECM are you using? I have found that '7747 does not like to power the Ostrich and requires an external power source.
AA is only needed for emulation, you can upload complete bins without disabling checksum without issue.
Old Jul 21, 2014 | 07:44 AM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Re: Ostrich Help
Using a 7730 ECM. Another thing I found odd was when I went for a drive, the car would 'hiccup' meaning go into limp mode and then come back out. Put in a chip and there are no issues.
Old Jul 21, 2014 | 12:20 PM
Re: Ostrich Help
If the Ostrich is connected to a laptop, even without having Tuner Pro open or emulating, does the problem go away?
Old Jul 21, 2014 | 02:31 PM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Re: Ostrich Help
I can have tunerpro closed and it does the exact same thing(unplugged from laptop it goes into limp mode, plugged in with tunerpro closed it works fine). I have checked the batteries and they appear fine.
355tpipickup
Aug 19, 2015 10:02 PM
jeeps2creep
17
Feb 4, 2007 10:30 PM
Grumpy
Oct 19, 2005 12:09 AM
anesthes
Sep 21, 2005 09:36 AM
smokefan
Apr 29, 2005 11:58 AM
