TunePro, Moates adapter
Old Jun 8, 2023 | 09:00 PM
GeekElite's Avatar
We've have a 89' Formula 350 TPI that is being redone. I purchased the Moates programmer and I'm using the TunerProRT program. I believe I have the .Bin, .XDF, and .ADX file's somewhat figured out. Currently I can write and read the chip.
We are going back with the L98 and changing a few things up. Cam, Heads, injectors, ect.
Just wanted to make sure that the ARAP 6E.bin, LC1Plugin.adx, and 6E.XDF are the right route to start with. (Sorry, first time doing PROM)
I pulled the ARAP for the factory info, (There is a ADS Powerchip currenlty installed that I will try to read and compare)
Any thoughts or help would be appreciated.
Old Jun 8, 2023 | 09:03 PM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Re: TunePro, Moates adapter
Originally Posted by GeekElite
We've had a 98' Formula 350 TPI that is being redone. I purchased the Moates programmer and I'm using the TunerProRT program. I believe I have the .Bin, .XDF, and .ADX file's somewhat figured out. Currently I can write and read the chip.
I putlled the ARAP for the factory info, (There is a ADS Powerchip currenlty installed that I will try to read and compare)
AT or MT?
What year? Says 98', did you mean '89?
If '89, it's MAF
Here's some info:
https://www.thirdgen.org/forums/diy-...ified-l98.html
Old Jun 8, 2023 | 09:04 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
98 ? or 89 ? Just solder is a dip socket and use a sst eeprom. Or uv erase your soldered in chip and use a more expensive burner. There’s also these not sure about quality.
https://www.ebay.com/itm/11570397684...mis&media=COPY
Old Jun 8, 2023 | 09:25 PM
GeekElite's Avatar
Appologies. New too all this still. It is AT, 1989. Corrected in OP
Wishmaster's87IROC
Nov 24, 2007 09:02 AM
mmaki
Oct 9, 2007 06:59 AM
Dr G
Apr 17, 2004 11:31 PM
Sostar18
Aug 4, 2002 08:48 AM
MJT
Dec 19, 2000 08:11 PM
