EBL flash ll port mod help
Car: Pos S10 blazer
Engine: 4.3 turbocharged
Axle/Gears: Stock g80 grenade 3:42
New member, long time lurker. I just found out about RBob yesterday while I was trying to contact him for the port mod upgrade for my EBL flash ll, I really hated to hear that, he was always so patient and helpful with any issue I was having. I noticed you guys are keeping his contributions and tech alive and was hoping someone here could help out.
I know RBob did the port mod in house but I've read somewhere how one can modify the TBI ECU (7747?) to fire in batch mode in order to fire all injectors on each bank once every revolution. Does anyone here know how to do this, have a write up, or offer the service? Thanks in advance and thank you for letting me join!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: EBL flash ll port mod help
The 747 is batch, are you going mpfi and want the 747 to control the load of 8 high impedance injectors ?
Car: Pos S10 blazer
Yes, this! Sorry for my lack of tech finesse. I'm trying to go from 2 tbi injectors to 6 high impendant injectors
Engine: Lb9
Transmission: M20
The 1228253 ecm was used for 6 cyl . I’m not sure you can convert the daughter board you have to work like the sfi-6
Engine: Lb9
Transmission: M20
Engine: Lb9
Transmission: M20
Car: Pos S10 blazer
Engine: Lb9
Transmission: M20
Car: Pos S10 blazer
Engine: Lb9
Transmission: M20
Dave w from gearhead found the info I was needing. Thanks again....https://www.gearhead-efi.com/Fuel-In...ull=1#post2855
Car: Pos S10 blazer
Im sure I was all over the place. I basically needed to know how to disable the PnH operation of a TBI ECU in order for it to operate saturated injectors. I just didn't know the terminology. The .zip file in that link may not be exactly what I was asking earlier here but it gets me close.
