calculating total timing?
Old Jan 29, 2002 | 10:49 PM
formula5's Avatar
How would I calculate(what tables) total timing with tunercat & 91 tbi bin?
Old Jan 30, 2002 | 08:35 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I'm not positive (I only had a brief moment to play with a 7747 this summer), but I think it is similar to SD where you need to add the base along with the Main Spark and PE to get your total spark advance in PE.
MAF is different in that the Main Spark Table also includes the base spark amount in the number, while SD is strictly the "relative" spark amount.
Old Jan 31, 2002 | 02:09 PM
formula5's Avatar
Thats what I thought but why is the tbi table so different than tpi.I was thinking of turning off the main spark bias.Would thid be a good idea?
Old Jan 31, 2002 | 02:56 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
re
The main spark bias in a tbi bin is set to 20, except in the 454tbi where its closer to 10.
From what I understand a lower number increases total spark and a higher number lowers it.
Is it a one to one ratio. if I move my main spark table down to 19 my overall spark goes up 1 degree?
Does the 20 mean 20 degrees of spark plus the main spark table plus the WOT spark table(only at wot of course)
How you you figure if it went to 19? Would I now have 21 degrees plus the main spark table plus the WOT?
Old Feb 3, 2002 | 12:02 AM
formula5's Avatar
What is the main spark bias?
Old Feb 3, 2002 | 02:14 AM
JPrevost's Avatar
Car: 91 Red Sled
I'm actually working out how to have winaldl display the total timing. I'm editing the eprom in the aldl stream to display the timing instead of the prom id.
I'll keep you guys posted when I get it to work.
, Jon
Old Feb 6, 2002 | 09:44 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: calculating total timing?
At DIY_EFI, Incoming is a tech paper on how the 747 figures timing. Might snag a copy of it to read.
Old Feb 6, 2002 | 09:59 AM
formula5's Avatar
thanks
Old Feb 6, 2002 | 07:58 PM
Aaron91RS's Avatar
Car: RS
I have already read that article. According to that you subtract the main spark bias form the the main spark table and WOT.
This can not be right.
Stock tbi RS's have a main spark bias of 20
WOT spark added of ~5 degrees
Last value at 100KPA and 3200RPMS of 16degrees on the spark table.
So 16+5-20=1
So a stock tbi runs 1 degree of advance, plus a couple more for coolant temp and extend spark slope. So maybe 5 degrees MAX timing.
I don't think so. So once again I ask what the main spark bias table does and how it effects timing
Vintageracer
Jan 10, 2020 05:33 PM
bellez77
Sep 5, 2015 08:39 PM
fasteddi
Sep 2, 2015 10:29 AM
neekolzun
Aug 24, 2015 04:59 PM
Dialed_In
Aug 20, 2015 01:45 PM
