anybody have the $32B definition file?
Old Jan 31, 2002 | 02:00 AM
87transam5.7tpi's Avatar
I downloaded the tuner cat demo and just wanted the $32B def. file to compare it too WINBIN and see which one i like better. thank you
Old Jan 31, 2002 | 06:06 AM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
Good luck on that one. I am sure lots of members have that, but they had to pay for it. This board frowns on licensed software theft and sharing. You would be better off just purchasing that .tdf file from Tuner Cat. WinBin stuff is freeware so it doesn't matter. Don't mean to sound like a jerk but thats the way this board operates and thats the way we want it.
Old Jan 31, 2002 | 07:16 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Actually, we don't "encourage" software sharing at the DIY Prom Board, as it P.O.s software suppliers.
However, TunerCat is very good about giving an older test version of a particular calibration during the evalutation period if you want. Just send them an e-mail and mention that you heard this from the guys at www.thirdgen.org that they will let you have demo tdfs.
Also, if I were you, I would look at the $6E (1989) version instead. The $6E is much better defined. And I would look at using one of the 1989 BINs including the ARAP BIN. Many guys with MAF have converted to the ARAP and found it much better. I also know a few people that found the ARAP a bit finicky - possibly they didn't tweak it well.
I do know the MAF Scalar Tables in the ARAP Bin result in best BLM/INT values on the cars I have looked at. Even if I use a different $6E BIN as a base, I usually recommend setting the MAF Scalar Tables to the same as the ARAP to start with.
Old Jan 31, 2002 | 09:57 AM
ok, sorry guys. I won't do that again, it was 1 last night I guess I just wasn't thinking :-) also glen are you saying use the 89 def. file and bin file? or use my 87 bin and read/edit witht he 89 def. file? thank you
Old Jan 31, 2002 | 10:05 AM
Car: Death Mobile
Engine: 666 c.i.
Use EVERYTHING for the $6E for the 1989 - forget the $32B. The 1989 setup has the best MAF Scalar Tables.
Old Jan 31, 2002 | 11:44 AM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
I switched from $32 to $6E and everything works great. There are alot more things to tweek in the $6E code. I am currently working with the ARAP bin and am making big improvments. Do a search on ARAP and check it out. If you decide to switch we can help you every step of the way.
Tom
Old Jan 31, 2002 | 11:59 AM
does anybody have an 89' .bin file I can get then? I have a 87 350 tpi right now. I think I'll buy that definition file then for that too
Old Jan 31, 2002 | 12:42 PM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
Go here ftp://ftp.diy-efi.org/pub/gmecm/bin_...%206E%2094/6E/ and get the ARAP 6E bin.
Old Jan 31, 2002 | 01:19 PM
thanks man, I think this stuff is gonna be fun! is it true that you can take about 3 tenths off of your et just from a good chip?
Old Jan 31, 2002 | 03:10 PM
SIMON HOLTBY's Avatar
I also switched from $32 to $6E and have not done any further tunning due to bad weather. But hey if it runs no better than at the moment I'm well chuffed.
Only problem I have corrected is the TC locked up too early for my liking. i know our cars are low reving but 700 rpm is pushing it. Maybe it is because I have a 2.77 axle ie high geared.
Last week I picked up a Toshiba Libretto laptop for $300 it is only the size of a video tape, colour screen and battery lasts a couple of hours. Will be ideal for tunning with.
All the best
Simon
Old Feb 8, 2002 | 07:38 PM
formula5's Avatar
I have gained about 1 sec in 1/4 mile.But my engine is far from stock.
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
tmellott89
Oct 14, 2015 02:06 PM
Jonas Earl
Sep 27, 2015 07:39 AM
MitcherNeaf
Sep 24, 2015 09:23 PM
