Thank you Craig Moates and a question for you
Old Mar 5, 2002 | 12:20 PM
Glen's Avatar
Engine: chevy 383
Transmission: tci streetfighter auto
Axle/Gears: 3.70 moser 9"
Thanks Craig for the effort producing the ALDL programs. I finally managed to get an old laptop and build a two transistor cable. I gathered my first data files and couldn't be happier to have a 'decent' tool to use. I had purchased an autoxray scanner and it only worked some of the time and has been a frustrating experience at best. I'm using your latest 8.50 version and it seems to work just fine. I have a question though. After communications are established, do you still need the 10K resistor to connector B? Is it a problem to leave it connected as you are doing the 'drive around' info gathering? I've seen some posts where it is suggested to remove it once comm is going, what is your take on the subject?
If you have a list of users I would like to be on it
glen.hunsberger@att.net
Thanks again,
Glen
Old Mar 5, 2002 | 10:10 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Glen,
The 10K resistor should only be necessary to establish communications with a 165-type ECM. Once the 8192 communications are established, the presence or absence of the resistor has no effect on performance or operation or anything. I'd say it'd be easiest to incorporate the 10K as part of your comm device and not worry about disconnecting it piecewise, but whatever your choice it should have no impact.
Hope this helps,
Craig
Old Mar 6, 2002 | 07:29 AM
Glen's Avatar
Engine: chevy 383
Thanks again Craig
Old Mar 6, 2002 | 03:53 PM
Sarkee's Avatar
I'd like to jump in here and mention (should any other newbies like me be reading this) that the built ALDL cables, like AKM sells, already have the 10K resistor built in and do not need another resistor installed in the ALDL socket...
Old Mar 8, 2002 | 02:41 PM
SIMON HOLTBY's Avatar
My engine always idles a few hundred rpm higher with the resister there so I remove it after making connection. I was concerned it was affecting other things.
Simon
Old Mar 8, 2002 | 05:18 PM
Car: 87 T/A
You sure? On mine, the idle is higher at first, but once comm is linked, then it drops back to normal...
Old Mar 8, 2002 | 10:06 PM
Chop_Top's Avatar
Interesting! 7747 TBI 10K built into cable
I had asked this board about the high idle and was told it was because of the aldl cable. (I had neve run the the motor with out it). I took out the cable and the idle was ok.
SO??? if the 10K is disconnected after start will it idle down to normal with the cable still connected? if so I will have to rebuild the cable.
Old Mar 10, 2002 | 03:03 AM
Guys,
I can only speak from my experience but the idle revs climb a couple of hundred rpm with the resistor connected. What I have done is fitted a small push button momentary switch under the dash with the resistor permanently wired. When I press the switch it grounds the resistor. I keep it pressed until I establish connection.
Simon
Old Mar 10, 2002 | 11:39 AM
jwfranklin's Avatar
ok as a admitted newbie... i have an 87 z28 250 TPI w/MAF (no other config w tpi? anyway)... i made a cable with the help of the win aldl schematic ( thanks mr joby and all others i am not aware of). i can connect using winaldl only if i put the 10K resistor across pins A-B and i have to leave them there for the win aldl software.
which brings my inspiration to contribute....i also have the factory service manuals and it says the 10k across A-B puts it in ALDL mode, which, bumps up the idle to 1000 rpm and bypasses some closed loop timers, and " some ecms will only output serial data in this mode", appears mine is?
so we should supposedly be able to remove the 10k after sync'ing? i tried mr moates's software and haven't been able to make it happy, but this is all as of yesterday.. still fiddling.
sorry if this was common knowledge and i am just rambling... anyway, i have learned so much from you all i wanted to add when i think i might actually know what i'm trying to talk about.
...over and out...
Old Mar 10, 2002 | 12:00 PM
jwfranklin's Avatar
addendum... (i think i know what that means... :P)
anyway, just found mr moates "new software" i don't know what version i had or what planet i've been on... but the new one rocks... the biggest bummer with winaldl is the 160 baud only, refresh every ~1.6 SEC? not an issue with 8192 baud?
so if you read this mr moates... rock on! :hail: and thank you for the sweet software. i have been trying to put together some matlab files for post data processing type stuff, so i can only begin to appreciate the amount of work you have invested... blah blah blah. thanks again.
john
Old Mar 10, 2002 | 09:59 PM
Chop_Top's Avatar
Originally posted by SIMON HOLTBY
Guys,
Simon
So, I ASSume you mean the idle drops back to normal when you release the button?
I know I could try it out but I will have to tear apart my cable and it is filled with stuff and never meant to come apart.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ZZ42Fast
Aug 30, 2015 02:39 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
