Battery Drain
Old Sep 15, 2000 | 07:36 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Battery Drain
I have an 88 Formula 350 with a factory GM alarm system. The battery will not hold a charge overnight. I need some ideas to help determine the source of the drain. I have not tested the alt for bleeding across the diodes yet.
My question would be what systems have access to battery power when the ignition is off? If possible I would like to disconnect systems and isolate the drain by trial and error.
Any suggestions would greatly appreciated.
Old Sep 15, 2000 | 08:21 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
The only systems I can think of off the top of my head is the alarm system and the memory/clock source for the radio. If you have any amplifiers added to your stereo, you may want to turn off your stereo and check to make sure that the remote turn on is off and not keeping your amps on. Check your alt to make sure it's fully charging.You can do this by checking the voltage at the battery with the car off, and checking voltage again with the car running. As you may already know, the voltage should be higher. But for now, that's all I can think of. If I think of anything else I'll let you know.
Old Sep 16, 2000 | 12:08 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Try putting an amp meter in series with the battery & measure the current draw with the engine off & all the doors closed. It shouldn't be more than 0.05 amps, or so.
If it is, then (after removing the dome & courtesy lights & unplugging the rear view mirror light, if your car has one) remove one fuse at a time, until the current draw is gone. That will tell you which circuit the current is bleeding through.
Tim
Old Sep 18, 2000 | 12:23 AM
Topgun's Avatar
It might be a bad battery too. Some batteries won't hold a charge. Have you batteryu and charging system checked
EMAIL: CTopgun5@aol.com
_______
84' Z28
New 350 Ci 4 Bolt Main with all L69/HO Parts
4 BBl Carb
160º Thermostat
K&N High Flow Filter
700R4 Trans
15X7 Standard Z28 Wheels, With 215/65R15 BF Goodrich Comp T/A HR4 Tires
Charcol in Color
no T-tops, but wish
New Head unit, JVC KD-SX750
New Kenwood 3-Way 6X9's
New Pioneer Sub
New Jensen 4-Channel Amp
As FiremanZ28 says "Friends don't let Friends Drive Mustangs"
Pic of my Z28, thanks to ZZ4 and his web page: Http://www.geocities.com/ukzz4iroc/z28camaro.jpg
Old Sep 18, 2000 | 02:14 AM
COUGAR's Avatar
i would start this one by checking out the battery. i have had this problem with all of my f-bodies. battery gets older, power drains over night, tried all of the trial and error stuff, and it always came down to a bad battery, here is what you do. when you get home to park the car for the night, disconnect the battery from the cables and let it sit there, if you come out in the morning and it is low on power, buy a new battery and all of your problems are gone, if it is still carrying power, start in with the trial and error elimination rounds.\
hope this helps you
Old Sep 19, 2000 | 11:09 AM
wm_sorg's Avatar
Gentelmen:
The battery checks ok. Looks like I have to hook up an amp meter and pull some fuses. Are there any hidden ones not in the fuse box?
Old Sep 20, 2000 | 12:39 AM
There is a 20 ampere fuse for the ECM, fuel pump, mass air flow relay, and burnoff relay near the battery, bolted to the frame near where the small ground wire from the "-" terminal from the battery attaches to the frame.
There may be a 4 amp in line fuse for the under hood light, near the hood hinge.
The alternator, coolant fan relays, blower high speed relay, light switch, fog light relay, and ignition switch are powered through "fusible links" down at the large terminal on the starter. They may be removed from the post on the starter, one at a time, if the fuse removals do not locate the source of the current drain.
Tim
Old Sep 26, 2000 | 04:06 PM
wm_sorg's Avatar
Tim are any relays supposed to be active then the car is off? When connecting and disconnecting the battery, I hear some relays activating on the relay block where the fuel pump relay is located.
Old Sep 27, 2000 | 12:50 AM
There is a MAF power relay and a MAF burnoff relay - one is near the battery & the other near the fuel pump relay - I'm not sure which is which, though. The burnoff relay has battery power to its coil & pole contact. The ECM grounds its coil to turn it on. I know that the burnoff relay remains on for a short time period, after the ign is switched off, so maybe it is cycling after the power up. It should not be on permanently, though.
Tim
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
drumstixer
Sep 29, 2015 03:02 PM
raymondandretti
Sep 27, 2015 06:43 PM
