INFL
Old Feb 21, 2001 | 06:46 AM
diznuff's Avatar
INFL
my 92 25th anneversiary camaro died on me and i finally figured out that all i need is a new alternator...but i have no idea what the "INFL reset" light on the panel next to the "service engine soon" light is. can anyone help me?
Old Feb 21, 2001 | 07:04 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Airbag, I believe... should flash a few times (self-test) and then go out.
KAM
Old Feb 21, 2001 | 07:12 AM
diznuff's Avatar
ya i figured it was something like that but when the self-test is over it is still there...i was figuring maybe the sensor or something isnt getting enough power to fully test it and just keeps it lit but i dunno.
Old Feb 21, 2001 | 11:19 AM
Car: '91 Z28
Axle/Gears: 323's
You might want to have that investigated... I don't have my book handy and don't know a whole lot about that stuff, but I think if the light stays on, it indicates a fault in the system somewhere...
KAM
Old Feb 21, 2001 | 11:49 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its actually INFL REST and it means inflation restraint system, or your airbag. Like Thunderstick said, if the light stays on all the time, you have a problem with your airbag that needs to be looked at. Unfortunately, thats not something you can do in your driveway. I think it requires special tools and knowledge.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
[This message has been edited by Kevin91Z (edited February 21, 2001).]
Old Feb 23, 2001 | 10:47 AM
diznuff's Avatar
i replaced my alternator and the problem went away.
Old Feb 24, 2001 | 09:19 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
The airbag probably set a code for low voltage. If you had ABS, the ABS light would have come on also. INFL and ABS are safety features, but can be dangerous if not working properly, so they are designed to shut off if the proper voltage is not recieved, to prevent the computers from making bad decisions, or not being able to carry the decisions out.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors, Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
rsrsrs
Nov 24, 2008 12:39 PM
prazav8
Jun 5, 2008 01:37 PM
nutcase-mark
Jun 3, 2008 01:27 AM
abyliks
Mar 3, 2007 09:28 PM
SLAYER6669
Jul 31, 2005 10:18 PM
