blinkers
Old Jul 15, 2002 | 01:33 PM
uidzer0_z28's Avatar
blinkers
Hey guys,
I was driving out to my cabin yesterday when I noticed that my blinkers dont "blink" they just stay on, the lights do come on but they don't blink, the lights in the dash come on as well but they don't blink either. I checked all my fuses and they all looked good, and I don't think it would be a bulb going bad because it was both the left and the right side.
heelp!!
thanks,
Ben
Old Jul 15, 2002 | 02:12 PM
RS'er's Avatar
sounds like your low on blinker fluid.
naw actually it sounds like you have a tail light out or possibly your flasher unit.
Old Jul 15, 2002 | 02:15 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
I'd check the same. Tail light out or your flasher fuse is dead.
Old Jul 15, 2002 | 02:53 PM
thanks for the fast replies guys,
I will definatly check my blinker fluid! = ]]
I will see if I have any lights out besides the blinkers, thanks guys.
Ben
Old Jul 16, 2002 | 11:49 AM
Well, I checked out the brake lights, they seem to be just fine. What could it be? You mentioned somthing about a flasher unit... where is this located?
Thanks,
Ben
Old Jul 16, 2002 | 12:15 PM
I did a search on where it is supposed to be, but I could not find it under the fuse panel, is it one of these on the panel?
Old Jul 16, 2002 | 12:17 PM
Eternal's Avatar
nope, you have to take off the whole bottom panel, and you will see another panel with all the flashers and relays
Old Jul 16, 2002 | 01:33 PM
maybee i have lost my mind but i can't find this panel, does anyone have a pic? Or might it be in a different spot on the 82'
Thanks,
Ben
Old Jul 16, 2002 | 04:12 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
TUrn on your hazzards & walk around the car. The hazzards will flash regardless of a light (turn signal element) being burnt out or not. On a camaro, the brakes have nothing to do with the operation of the turn signal
The turn signal relay is clipped to the steering column brace under (above technically) the 'convenience' panel (to the right of the steering column. The 'hush' (trim) panel has to come off to see this. The convenience (I swear I'm spelling that wrong..) panel will swing out of the way to (barely) get to the signal flasher. But that's based on my 84, the 83 I pulled a column from & an 85 I yanked the harness from...
Old Jul 16, 2002 | 04:14 PM
Hey thanks alot, I will try that when I get done w/ work.
-Ben
Old Jul 17, 2002 | 01:27 PM
I still can't find it!!
Does anyone have a picture?
thanks,
Ben
Old Jul 17, 2002 | 01:32 PM
Eternal's Avatar
its right above your right knee.... you have to take the bottom dash cover off to get to it.
Old Jul 17, 2002 | 01:38 PM
lol, I'll try again I took that cover off before and I couldn't find anything... What exactly does it look like?
-Ben
Old Jul 17, 2002 | 02:22 PM
deadbird's Avatar
Engine: TPI 305/ v6
Lucky for you, 2 steering columns later, I got sick of putting the camaro back together...
Old Jul 17, 2002 | 03:28 PM
thank you!!
Old Feb 21, 2007 | 07:25 AM
bandit too's Avatar
flasher relay?
I have a similar problem on my 89, in the convenience centre there are 2 relays, 1 round and 1 square, which is which?
Old Feb 23, 2007 | 07:14 PM
built's Avatar
Car: 82 TA
I have the same problem on my 82 TA.
The lights flash super slow or not at all when the brake is on.
I'm going to get a new relay in a couple days and i needed to know where it went also.
Is it in the same place for a TA ?
Old Feb 26, 2007 | 11:00 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
most likely, its going to be in the same place or at least in the area.
I do have a question though, how about the flasher unit for the hazards? I know at least on the older cars there were two units, is it in the same place?
Basically Im going to be ungrading my taillights (with luck in finding the darn bulbs) to LED bulbs, which need different flasher units.
Thanks.
Old Feb 27, 2007 | 01:03 AM
Grim'91Z's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7L V8
Transmission: 700R4 Auto
Haha, same for my car. Only the left one stays solid, right one works perfectly fine.
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Jk_Under
Sep 2, 2015 10:59 PM
bklucas12
Jan 11, 2002 06:44 AM
super83Z
Jun 2, 2001 10:44 AM
Jimmy91RS
Sep 28, 2000 02:16 PM
