Oil pressure sending unit.
Old Apr 26, 2001 | 04:54 PM
87 Trans Am TPI's Avatar
My oil pressure sending unit went out, its a digital dash, the gauge reads zero, where is the unit and whats it gonna cost. Thanks.
1987 Trans Am
5.0L TPI
Automatic, all pwr. op
Digital Dash
Flowmaster Muffler
gutted cat
removed MAF screens
TransGo Shift Kit
Old Apr 26, 2001 | 08:41 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
It's located right above the oil filter, on the block. You'll need the 1 3/16 socket for it, or some other large tool. If I recall, the cost on a new one is about $25-30. It's bee awhile since I replaced mine...
KAM
Old Apr 26, 2001 | 09:12 PM
Where can I get a sending unit?
Old Apr 28, 2001 | 01:36 AM
stephenc's Avatar
you can get these sending units at autozone for $25. don't bother getting one at a recycling yard, you'll get a lot more mileage out of a new sending unit.
stephenc -- 89 GTA
Old May 1, 2001 | 03:15 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Actually, in '87, I believe that the oil pressure gauge sending unit is located at the rear of the block, below the distributor. The sender above the oil filter is an oil pressure switch, used in parallel with the fuel pump relay, to operate the fuel pump. I'm not sure what year GM combined the oil pressure sending unit with the fuel pump switch.
Tim
Old May 1, 2001 | 08:38 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Yep, it's right below the intake manifold in the back closer to the drivers side... I think it's around $15
Old May 2, 2001 | 03:41 AM
pookey's Avatar
Where would it be on a 88 305 TBI?
Old May 2, 2001 | 08:36 AM
JoelOl75's Avatar
prolly the same spot. no guarantee...
The one in the block was used for the fuel pump switch in the later years.
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
