Theft deterent key?
Old Aug 17, 2001 | 04:53 PM
tiogarider's Avatar
Theft deterent key?
I have a 92 firebird and has that key with the chip in it. Anyways its broke it will turn 360 degrees and not do anything. Can I replace it with one that doesn't have the chip or not?
Old Aug 17, 2001 | 05:08 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I think you can, but your VATS won't work anymore. This is one of the ideas for getting arounf the VATS if you swap to a carb from FI.
Joshua Johnston
1991 Z-28
Flowmaster
K&N
305 / 5spd. (Temporary)
Soon to have:
350, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust, T&R Motorsports custom air intake
Old Aug 22, 2001 | 02:17 AM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
tioga, check my post on the question vat's key value, its long but it may help go to the third suggestion its cheaper and DONT change out your TPI for a carb not just over this anyway.
Jack
'87 Monte Carlo SS,with '89 IROC 350,700 trans, blew up 3.73 posi stuck with crappy 2.73's neeed gears! hooker headers, flowmaster 2 1/2" exhaust true dualls, recently installed a set of alum vette heads 58cc, new cam for a paxton, recently installed paxton, OMG need a posi bad. Found a guy who can build me a ford 9" (yep sorry guys) for less than 500 then comes all the goodies such as disk brakes so on and so on, will it ever end?? I hope not!!
Old Aug 22, 2001 | 05:51 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
If your lock cylinder is spinning 360* and not doing anything, then a new one probably won't change a thing. It sounds like the rack and/or sector is busted. The rack is made out of "pot metal" and I see a few of these break. It is what actuates the rod for the ignition switch. When this beaks, it allows the lock cylinder to just spin. Of course if you have been turning the lock cylinder like that, than you probably did break teh wires going to it and will need one now.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
Linson
Oct 1, 2015 09:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
